Kawaski 2019 mule pro mx eps kaf 700
   / Kawaski 2019 mule pro mx eps kaf 700 #1
chase729
Leechburg PA
Kioti CK 27
Ran good for 80 hrs. Started to be hard starting. Changed plug Now plugs don't help or have to keep changing. Using ethanol free gasoline. any suggestions
   / Kawaski 2019 mule pro mx eps kaf 700 #2
3 year warranty on Kawasaki. I’d make it the dealers problem. I just bought a 2021 model. I really like it. Hope it’s not something that’s an issue with all of them.
   / Kawaski 2019 mule pro mx eps kaf 700 #3
I'd take it back to whomever performed the first service at (I think) 25 hours because valves were to be checked. Tight valves will make it hard to start.
   / Kawaski 2019 mule pro mx eps kaf 700 #4
If not the valves (yes they should be checked), I am guessing fuel delivery (fuel pump or filter) or throttle body problem.
I would have a dealer determine the problem, it should be covered by the three year warranty.
   / Kawaski 2019 mule pro mx eps kaf 700 #5
As strange as it sounds, try regular gas. I had a Honda pioneer 700 that was hard starting when it was new. I talked to the dealer and told me that the single cylinder engines with EFI are tuned to use regular gas and that the ethanol free gas burn slower (higher octane) which causes the single cylinder engines to start hard. Switched to regular and it got better, not great, but better.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
Xtreme XR1045 (A50120)
Tallman 6" Water Pump (A50774)
Tallman 6" Water...
