Kawaski 2019 mule pro mx eps kaf 700
   / Kawaski 2019 mule pro mx eps kaf 700 #1
chase729
Leechburg PA
Kioti CK 27
Ran good for 80 hrs. Started to be hard starting. Changed plug Now plugs don't help or have to keep changing. Using ethanol free gasoline. any suggestions
   / Kawaski 2019 mule pro mx eps kaf 700 #2
3 year warranty on Kawasaki. I’d make it the dealers problem. I just bought a 2021 model. I really like it. Hope it’s not something that’s an issue with all of them.
   / Kawaski 2019 mule pro mx eps kaf 700 #3
I'd take it back to whomever performed the first service at (I think) 25 hours because valves were to be checked. Tight valves will make it hard to start.
   / Kawaski 2019 mule pro mx eps kaf 700 #4
If not the valves (yes they should be checked), I am guessing fuel delivery (fuel pump or filter) or throttle body problem.
I would have a dealer determine the problem, it should be covered by the three year warranty.
   / Kawaski 2019 mule pro mx eps kaf 700 #5
As strange as it sounds, try regular gas. I had a Honda pioneer 700 that was hard starting when it was new. I talked to the dealer and told me that the single cylinder engines with EFI are tuned to use regular gas and that the ethanol free gas burn slower (higher octane) which causes the single cylinder engines to start hard. Switched to regular and it got better, not great, but better.
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
