Kawaski 2019 mule pro mx eps kaf 700
   / Kawaski 2019 mule pro mx eps kaf 700 #1
chase729
Leechburg PA
Kioti CK 27
Ran good for 80 hrs. Started to be hard starting. Changed plug Now plugs don't help or have to keep changing. Using ethanol free gasoline. any suggestions
   / Kawaski 2019 mule pro mx eps kaf 700 #2
3 year warranty on Kawasaki. I’d make it the dealers problem. I just bought a 2021 model. I really like it. Hope it’s not something that’s an issue with all of them.
   / Kawaski 2019 mule pro mx eps kaf 700 #3
I'd take it back to whomever performed the first service at (I think) 25 hours because valves were to be checked. Tight valves will make it hard to start.
   / Kawaski 2019 mule pro mx eps kaf 700 #4
If not the valves (yes they should be checked), I am guessing fuel delivery (fuel pump or filter) or throttle body problem.
I would have a dealer determine the problem, it should be covered by the three year warranty.
   / Kawaski 2019 mule pro mx eps kaf 700 #5
As strange as it sounds, try regular gas. I had a Honda pioneer 700 that was hard starting when it was new. I talked to the dealer and told me that the single cylinder engines with EFI are tuned to use regular gas and that the ethanol free gas burn slower (higher octane) which causes the single cylinder engines to start hard. Switched to regular and it got better, not great, but better.
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
GMC 3500 Ambulance (AS IS)(NO TITLE) (A50774)
GMC 3500 Ambulance...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
Portable Creep Feeder with Gates (A50515)
Portable Creep...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
