Kawasaki engine stalling - JD325
/ Kawasaki engine stalling - JD325 #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
I have an 18 hp Kawasaki on my 325. While engaging mower deck when engine is cold...the engine stalls. If I wait until It's fully warmed up the engine will not stall and recover. thoughts?
/ Kawasaki engine stalling - JD325 #2
Sounds like a carb/choke/governor issue
/ Kawasaki engine stalling - JD325 #3
Does this engine have one cylinder or two? My Kohler was acting that way until I noted one cylinder wasn't working at all.
/ Kawasaki engine stalling - JD325 #4
My 425 with twin Kawasaki engine will do that too when the power flow is also belted up to the mower deck.
A timely flick to "choke and off" at the same time the mower switch is pulled will catch the engine in time to keep it going.
/ Kawasaki engine stalling - JD325 #5
Many Kawasaki's are cold blooded. Keeping your fuel in check IE fresh and clean helps. A little Seafoam every now and then doesn't hurt. Let it warm for now and update the fuel. Should it not be where you like it, you could delve into the carb at the next PM.
/ Kawasaki engine stalling - JD325 #6
I have 2 Kawasaki's on JD Ztracks. I can tell you this will get to the point it will do it with the engine hot as well. Both of mine have. Both times it was the plugs. They looked good but after I changed them no more stalling.
/ Kawasaki engine stalling - JD325 #7
I have an 18 hp Kawasaki on my 325. Kawasaki's engine is good.
/ Kawasaki engine stalling - JD325 #8
Mine does the same thing. I just move the choke lever up until it starts to run a little rough then engage the PTO. I don't think there's anything wrong.
2000 Hino (A64194)
2000 Hino (A64194)
7" X 7" TOOLBAR W/ EXT. (A64278)
7" X 7" TOOLBAR W/...
2018 Ford F-150 Crew Cab Pickup Truck (A64556)
2018 Ford F-150...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
CATERPILLAR D3GXL CRAWLER DOZER (A65053)
CATERPILLAR D3GXL...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
