Kats heater placement on GT235
   / Kats heater placement on GT235 #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I just picked up their 200w magnetic heater. Now where should I place it? :)
   / Kats heater placement on GT235 #2
Where it is steel, and what you want to heat... likely oil.
What did you have in mind before buying it? Cold start for blowing/plowing snow?
I want the oil heated prior to cold starts. The block doesn't appear to be steel; hope I didn't just make a bad purchase!
   / Kats heater placement on GT235 #4
With an aluminum block and oil pan it could be challenge to use a magnetic heater. Usually magnetic heaters were mounted to the oil pan so the heat would rise.
   / Kats heater placement on GT235 #5
Use synthetic oil in the engine and you should have no problem with thick oil restricting starting in cold weather.
   / Kats heater placement on GT235 #6
Take it back and get your money back.
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A50459)
JOHN DEERE 975 3...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2016 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2016 FREIGHTLINER...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A48836)
2006 Hino 268...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
377783 (A48837)
377783 (A48837)
