Kats heater placement on GT235
   / Kats heater placement on GT235 #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I just picked up their 200w magnetic heater. Now where should I place it? :)
   / Kats heater placement on GT235 #2
Where it is steel, and what you want to heat... likely oil.
What did you have in mind before buying it? Cold start for blowing/plowing snow?
I want the oil heated prior to cold starts. The block doesn't appear to be steel; hope I didn't just make a bad purchase!
   / Kats heater placement on GT235 #4
With an aluminum block and oil pan it could be challenge to use a magnetic heater. Usually magnetic heaters were mounted to the oil pan so the heat would rise.
   / Kats heater placement on GT235 #5
Use synthetic oil in the engine and you should have no problem with thick oil restricting starting in cold weather.
   / Kats heater placement on GT235 #6
Take it back and get your money back.
UNUSED Bubble Aluminum Foil Reflective Insulation (A50860)
UNUSED Bubble...
2011 FORD F-250 SUPER DUTY FLATBED TRUCK (A50459)
2011 FORD F-250...
(1) HD 24ft Free Standing Corral Panel (A48837)
(1) HD 24ft Free...
1267 (A50490)
1267 (A50490)
2009 Audi Q5 Quattro AWD SUV (A48082)
2009 Audi Q5...
Case 580 SuperK Loader Backhoe (A50860)
Case 580 SuperK...
