Karaoke player question
/ Karaoke player question #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
I want a karaoke player and see some on ebay that are apparently glorified dvd players.
Can you play karaoke dvd's on a regular dvd player and where would the mike go if i don't have a surround sound yet?
What would be lacking on a regular dvd player?
signed Elvis
/ Karaoke player question #2
A karaokee player setup generally is playing Cd-G which is cd with graphics. That way you can hook up a video monitor and see the bouncing ball. The karaokee machine setups usually have a place for a couple mics, generally ballanced or unballanced 1/4 connections ( yuck!), and controlls, and a built in speaker... The better units may have audio out, for hooking up to a seperate amp, or at least speaker lvel out for attaching other speakers... May have better mic channels.. perhaps even ballanced xlr inputs.. though I've not seen a unit with phantom power.. I think the more you pay, the better mixing controls you get... graphic/parametric eq, better sweeps, presence or lack of a mic pre-amp, better effects section. I've sene some American DJ equipment even have key correction / pitch bending / shifting, and a vocal remover for playing a regular cd.. which just more or less just carves the 'middle' out...
You can find them from 19$ and up at walmart.. or if you want a dj or pro level job, hit a place like musicians friend ont he web, or Sam Ash.. they both have DJ sections.
Soundguy
/ Karaoke player question #3
Really it depends on the format of the Karoke disk. The older format was as SoundGuy states, CD+G. This requires a special CD player that can read the graphics content of the disk. Most standard CD players can't read these tracks. A lot of computer CD-RW burners could read them but not burn them.
They are available now in DVD format. The DVD Karaoke disks will play on any DVD player. You would just need a small mic mixer and a receiver, or better yet a separate PA system for the microphones. Again though, you must be sure of the format that the karaoke disk is produced in; CD+G or DVD. If it is CD+G it needs a special player, if it is DVD any DVD player will work.
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Hydrapack 6 Row Lay-By-Rig (A64127)
Hydrapack 6 Row...
Deere 672GP (A64126)
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
