KAMA Hydraulic Question
/ KAMA Hydraulic Question #1
3RRL
Super Member
Foothills of the Giant Sequoia's, California
55HP 4WD KAMA 554 and 4 x 4 Jinma 284
KAMA 554
I don't know if the rear tractor hydraulic system is closed or open center...maybe you can tell me? I'm trying to get this information for the Top and Tilt system.
I was told that I will not need the joystick controls because the tractor has 2 sets of rear hydraulics on it...is that correct?
Thanks
/ KAMA Hydraulic Question #2
Your tractor has an open center system which means the hydraulic pump is always pumping fluid. Fluid is continuously flowing from the tank thru the pump thru all valves and back to the tank.
As I indicated in a post in a different forum, you already have two rear remotes which can connect to a hydraulic top link cylinder and hydraulic side/tilt link cylinder. You should have 2 levers on the fender that will control these rear remotes.
/ KAMA Hydraulic Question #3
Mad was right in the other post. All you need is the cylinders, hoses and end fittings.
/ KAMA Hydraulic Question #4
regardless... you need to get some plugs for those disconnects to keep dirt out.
x (A68191)
x (A68191)
20t Ton Air/Manual Hydraulic Bottle Jack (A64557)
20t Ton Air/Manual...
CAT 953C Cab (A68134)
213141 (A64276)
213141 (A64276)
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
