kabota f2000
/ kabota f2000 #2
Yep, got two of them, no better large area mower ever built! /forums/images/graemlins/cool.gif
/ kabota f2000
i have a problem will sloppy steering and all the joints seem ok .any advice
/ kabota f2000 #4
No slop in the cylinder mount? Do you have any delay in responce? or just extra motion in the wheel before the cylinder moves?
/ kabota f2000
its best discribed that when i'm mowing i'm forever fighting thr wheel to keep it striaght.i've only had i a few months and trying fix her up for the upcoming season.thanks
/ kabota f2000 #6
Have you changed the filter under the fender and cleaned the suction screen from the pump? Is the level correct on the hydraulic fluid? How many hours are on the unit?
/ kabota f2000
ah so! i have ordered a owners manual but it is still not in.i will check what you have suggested .also the mower deck has a alot of side to side movement.will adjusting to two large springs cure this? thanks again. steve
/ kabota f2000 #8
Remember that your unit has hydraulic steering, there is no mechanical linkage so there will be some sloppiness. /forums/images/graemlins/smile.gif
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
Vermeer 5400 Rebel Hay Baler (A61166)
Vermeer 5400 Rebel...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
