K5055
/ K5055 #1
PatMcD
Maine
LS U5030
I was toying with the idea of a NH Workmaster 55 and then heard that LS K5055 is pretty darn close to being the same for a little less money.
My questions:
1. Is the LS transmission a shuttle shift like the NH?
2. Any idea the price the bare-bones tractor plus FEL is going for these days? Nearest LS dealer is 2hrs away and I usually want to talk in person with salesmen.
/ K5055 #2
Heres the specs:
Engine
Type: 4-cylinder, Indirect – injection, Water-cooled
Model (Tier 4 Interim): LS S4S
Engine HP (Gross): 55
PTO HP: 46
Rated Speed, RPM: 2500
Displacement - cu. in.: 203.3
Fuel Tank Capacity (gal): 22.5
Alternator: 12V - 50 Amps
Drive Train
Transmission: Sliding Gear Shifting
No. of Speeds: 8 forward / 4 reverse
Brakes: Wet, Multi Disc
Steering: Hydrostatic Power Steering
PTO
Type: Dual Clutch
Mid PTO: N/A
Rear PTO: Standard (540 rpm) / 2409
Hydraulic System
Implement pump, gpm: 9.9
Steering pump, gpm: 4.8
Total flow gpm: 14.7
Category, 3 pt hitch: CAT 2
Hitch Lift capacity, lb: 3,526
Lift control type: Position / Draft
Dimensions
Overall length with 3pt: 136.3"
Wheelbase: 82.3"
Min. overall width with AG tires: 70"
Height to top of ROPS with Ag tires, in.: 104.6"
Tire Size
Ag Front/Rear: 11.2 - 20 / 14.9 - 30
Industrial Front/Rear: 10.5 x 80-18 / 18.4 - 24
Turf Front/Rear: NA
Weight
Total weight without ballast, lbs.: 4,453
Hope that helps
/ K5055
Thank you.
I'm guessing a "sliding gear shifting" transmission is basically a simple geared transmission (have to clutch every gear, forward and back).
I'm looking to upgrade out of that (which I already have), so I'll be looking at another LS series.
/ K5055 #4
I bought the xr4046hc, which is the largest horsepower Hydro stat model that they make. it is 46hp and 35 at the pto.
/ K5055
I'm up in Maine.
I found a dealer closer than the one the LS site recommended. Only a hour or so away.
/ K5055 #7
I am looking at that model here in Louisiana the dealer is offering me that tractor for 22K. Still researching if this is a good price or not
/ K5055 #8
I just priced a K5055 from my dealer here in Ohio. Quoted $22,290 including a Remote Valve, loader and Freight. Hoping to get filled tires thrown in.. I'm going to an auction this weekend and if I don't get anything I'll be pulling the trigger next week.
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
Club Car Emergency Cart (A64557)
Club Car Emergency...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
