K5055
/ K5055 #1
PatMcD
Maine
LS U5030
I was toying with the idea of a NH Workmaster 55 and then heard that LS K5055 is pretty darn close to being the same for a little less money.
My questions:
1. Is the LS transmission a shuttle shift like the NH?
2. Any idea the price the bare-bones tractor plus FEL is going for these days? Nearest LS dealer is 2hrs away and I usually want to talk in person with salesmen.
/ K5055 #2
Heres the specs:
Engine
Type: 4-cylinder, Indirect – injection, Water-cooled
Model (Tier 4 Interim): LS S4S
Engine HP (Gross): 55
PTO HP: 46
Rated Speed, RPM: 2500
Displacement - cu. in.: 203.3
Fuel Tank Capacity (gal): 22.5
Alternator: 12V - 50 Amps
Drive Train
Transmission: Sliding Gear Shifting
No. of Speeds: 8 forward / 4 reverse
Brakes: Wet, Multi Disc
Steering: Hydrostatic Power Steering
PTO
Type: Dual Clutch
Mid PTO: N/A
Rear PTO: Standard (540 rpm) / 2409
Hydraulic System
Implement pump, gpm: 9.9
Steering pump, gpm: 4.8
Total flow gpm: 14.7
Category, 3 pt hitch: CAT 2
Hitch Lift capacity, lb: 3,526
Lift control type: Position / Draft
Dimensions
Overall length with 3pt: 136.3"
Wheelbase: 82.3"
Min. overall width with AG tires: 70"
Height to top of ROPS with Ag tires, in.: 104.6"
Tire Size
Ag Front/Rear: 11.2 - 20 / 14.9 - 30
Industrial Front/Rear: 10.5 x 80-18 / 18.4 - 24
Turf Front/Rear: NA
Weight
Total weight without ballast, lbs.: 4,453
Hope that helps
/ K5055
Thank you.
I'm guessing a "sliding gear shifting" transmission is basically a simple geared transmission (have to clutch every gear, forward and back).
I'm looking to upgrade out of that (which I already have), so I'll be looking at another LS series.
/ K5055 #4
I bought the xr4046hc, which is the largest horsepower Hydro stat model that they make. it is 46hp and 35 at the pto.
/ K5055
I'm up in Maine.
I found a dealer closer than the one the LS site recommended. Only a hour or so away.
/ K5055 #7
I am looking at that model here in Louisiana the dealer is offering me that tractor for 22K. Still researching if this is a good price or not
/ K5055 #8
I just priced a K5055 from my dealer here in Ohio. Quoted $22,290 including a Remote Valve, loader and Freight. Hoping to get filled tires thrown in.. I'm going to an auction this weekend and if I don't get anything I'll be pulling the trigger next week.
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2001 UNKOWN  GOOSENECK PUMP TRAILIER (A65643)
2001 UNKOWN...
2437 (A65640)
2437 (A65640)
King Kutter II Tiller for sale.
King Kutter II...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
