K46AC Gears
/ K46AC Gears #1
NutzTN
Middle TN
02 Scotts L2048
I started repair as others have on my TT K46AC. The L2048 has 337 hrs on the ticker. The two magnets were saturated with metal shavings and the lube was black as asphalt. Some of the gears had serious wear:
http://lh3.ggpht.com/_YHBGzleh_WA/TBsLizqwEWI/AAAAAAAAAao/--igpqxnSwg/s800/k46ac_1.jpg
Above is the final pinion gear that drives the final gear (differential) and a reduction gear that drives the brake disk motor gear.
http://lh5.ggpht.com/_YHBGzleh_WA/TBsLuYX8gZI/AAAAAAAAAa8/6bFOqao6P6Y/s800/k46ac_3.jpg
Note the pointed teeth
http://lh4.ggpht.com/_YHBGzleh_WA/TBsMAC8wvNI/AAAAAAAAAbY/ERN5csAfuYE/s800/k46ac_8.jpg
The differential gears didn't look all that good , so I will be replacing those also - 4 gears with a little roller shaft pin.
http://lh5.ggpht.com/_YHBGzleh_WA/TBsLZeg42wI/AAAAAAAAAak/moO71JDA20A/s800/k46ac-4.jpg
fortunately all matching gears come in a kit including the roller pins
http://lh6.ggpht.com/_YHBGzleh_WA/TBsL8Bpii7I/AAAAAAAAAbU/sI5DsEpvnFs/s800/k46ac_7.jpg
http://lh3.ggpht.com/_YHBGzleh_WA/TBsLqXqW-0I/AAAAAAAAAa4/Cq1EDJU8uvk/s800/k46ac_2.jpg
These probably would last another season (or 2) but why wait and take a chance that these could take out the whole unit.
Another note: if you have a K46 with this many hours and there hasn't been anyone inside, you may expect to find similar wear. The trans is not that hard to dismantle, just a little tricky keeping up with the small BB's and pins.
Mike
New Holland Work Master 75 Tractor (A61166)
New Holland Work...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
MANCHESTER 80 GALLON AIR COMPRESSOR (A62131)
MANCHESTER 80...
2003 McCormick XTX 185 XtraSpeed Tractor (A63118)
2003 McCormick XTX...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
