K&M mechanical seat upgrade on MX5200
   / K&M mechanical seat upgrade on MX5200 #1
nicb803
South Carolina
Kubota MX5200 4x4 HST
Finally decided to upgrade the seat on the new MX. Back was taking a beating and taking days to recover after any extended amount of time on the tractor. If you are contemplating a seat upgrade, quit procrastinating and do it. The difference in ride and comfort are night and day, your back will thank you. A few hundred bucks is cheaper than a chiropractor or surgery any day! Took almost 2 hours for the install, but there was an issue with the mounting plate not aligning correctly. Instead of returning I decided to just drill another hole since only 1 hole was off. Do not hesitate to ask questions if you need, very simple and you will not regret the change, just regret not doing it sooner!!!
   / K&M mechanical seat upgrade on MX5200 #2
Congratulations on this upgrade. I recently put one on my Deere z930 for the same reason and what a difference in comfort it has made!! I was worried the limited travel wouldn't really provide a noticable difference or if the springs would provide enough compression damping for 200+ lbs operator. I am well pleased on both accounts and would recommend this upgrade to anyone seeking more comfort!
   / K&M mechanical seat upgrade on MX5200 #3
Maybe post a model # and photo of the seat you used? Might save someone some time if they want go a similar route.
136 Uni pro seat with Grammer MSG65 mechanical suspension kit.
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
378467 (A51572)
378467 (A51572)
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2014 Ford Fusion SE Hatchback (A55853)
2014 Ford Fusion...
