jx85
   / jx85 #1
tonytoe
case jx85
where to get hydraulic power for loader bucket
   / jx85 #2
The specs for your machine is open center and 13 GPM.
It also says standard valves 3 .
If you have just installed a loader, and no valve for it, then you need a joystick valve with PB to complete the circuit.
http://www.surpluscenter.com/item.asp?item=9-4782&catname=hydraulic
Hydraulics
• Standard Valves: 3
• Type: open
• Valve Flow: 13.6 gpm
General
• Manufacturer: caseih
• Model: jx85
• Series: sii_jx85.pdf'>pdf file
• years produced: 2002 - 2006
   / jx85
I have joystick,but I need to know where to get my hydraulic power from other than from the farm impliment supply ports
   / jx85 #4
Can you tell me what you have for hyd from the pump to the reservoir?
If you have a loader, it may have a PB outlet.
What is your goal? Add more hydraulics, such as remotes at the rear.
If all you have now is 3pt, then the flow is from the pump to the 3pt, then reservoir.
If you have a loader the flow is probably from the pump to the FEL valve then to the 3pt , then to reservoir.
You have an open center hyd system, so all valves should be in series.
Life proof SPC Luxury (A53117)
Life proof SPC...
2017 KENWORTH T800 (INOPERABLE) (A53843)
2017 KENWORTH T800...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
