Just stumbled across this -- PT-1425
   / Just stumbled across this -- PT-1425
Yes, Bob, that would meet my definition of a fully-pressurized system, if the camshaft and crankshaft (rods & main bearings) are pressurized, which it states to be the case. Interesting that they'd describe it like this:
>>All models offer heavy-duty features including aluminum alloy blocks with cast iron cylinder liner, electronic ignition with automatic timing adjustment, dual ball bearing supported crankshaft, automatic decompression system, and splash lubrication system . <<
On this page:
Subaru Robin V-Twin Cylinder Series
You'd think they'd be emphasizing the pressurized lubrication system instead....
Interesting!
   / Just stumbled across this -- PT-1425 #12
Dang, I step away to watch a movie, and posts are popping up like mushrooms on a manure pile.
<font color="red">"The splashed engine oil is provided to the cylinder, piston, and cylinder head valve system".
</font>
<font color="red">“Dual ball bearing supported crankshaft, automatic decompression system, and splash lubrication system. “
</font>
This is where I got the impression that it was a splash system. Not sure why they word it that way. I’ve been so busy using the machine that I’ve not really researched it as much as I would like. That’s good news though, thanks for clearing that up. (No joke.) /forums/images/graemlins/smirk.gif
Reading Bob's descriptions a bit more closely, I would point out that the valves appear to be splash lubed, whereas in an OHV car engine, for example, the oil is pumped up through the pushrods, oiling the rocker arms and shafts, and drains back down to the oil pan.
I wonder exactly how the rocker arms are lubed...
   / Just stumbled across this -- PT-1425 #14
Thanks Doc,
Good to know. Didn't mean to stir up a hornets nest here. /forums/images/graemlins/tongue.gif
   / Just stumbled across this -- PT-1425 #15
The Briggs in my Craftsman is a single cylinder splash. I'm sure it will hold up just fine. I'll bet the frame, and cheap components won't last more than 10 years. Cool looking old tractor. /forums/images/graemlins/smirk.gif
   / Just stumbled across this -- PT-1425 #16
Not sure, but I'll take it. Being the smaller engine in the fold, and as hot as that engine gets nice to know it has a pump, and forced lubrication of any kind. I did just get in an order of Amsoil for it's second oil change, that should help. /forums/images/graemlins/smirk.gif
Now, back to the original question -- does anyone know anything more about the PT-1425? /forums/images/graemlins/grin.gif
   / Just stumbled across this -- PT-1425 #18
I don't know does it have a splash lube? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( I don't know does it have a splash lube? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif )</font>
Nope, it has a Kohler Command! /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/cool.gif
   / Just stumbled across this -- PT-1425 #20
I believe that all engines that have an oil filter are considered pressure lubed. A little splash lube would not hurt either. Now if you could figure out which side the pump was on, you could run that engine at a greater angle. MAYBE
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
Black Metal Roof Panels (A55758)
Black Metal Roof...
(1) 10000 LB GEAR REDUCTION DROP LEG TRAILER JACK (A57192)
(1) 10000 LB GEAR...
2013 Audi Q7 AWD SUV (A55853)
2013 Audi Q7 AWD...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
