Just some Q's needing Aed.
/ Just some Q's needing Aed. #1
BigFarminMike
Moores Hill, Indiana
Kubota L3000DT 4WD
Ok so just a few stupid qustions. One I have a Kubota L3000 DT 4WD and there is a hash mark on the rpm meter what does that mean? I also need a bit more weight in the front what can I cheaply do about this? Oh and my turn signals will not work... Any ideas? I bought new bulbs
/ Just some Q's needing Aed. #2
The hash mark is the RPM needed to turn the PTO at exactly 540 RPM, the normal rated speed for most pto-driven attachments. Note that it's often not necessary to run at exactly 540; lots of attachments will work just as well (sometimes better) at a lower speed. But there are some things that need 540 and no less... a PTO-driven generator would be an example.
You can buy suitcase weights. The Kubota ones are not cheap, but you might pick up some old ones that would work at a scrap yard or on Craig's etc.
Turn sigs... connector, bad flasher are the most likely. Maybe the switch also. Time to play amateur electrician. Best of luck.
Thanks for the help. Now the good question is when traveling on the road, is the tractor rated to run above the hash mark or would that me to much stress on the engian?
/ Just some Q's needing Aed. #4
The engine should be RPM limited so you could run it at full throttle which on most models will be slightly above the hash mark.
/ Just some Q's needing Aed. #5
Check the fuse on your turn signals before going too far. Eliminate the simple things first then work to more complicated/expensive. Just my .02 worth. Do your other lights work? I don't know if all lights are on same fuse or not.
/ Just some Q's needing Aed. #6
On the road, run max rpm, it is not a redline, it is designed to turn that fast, it is normally called max high idle. Philip.
UNUSED AGT - AC AIR COMPRESSOR (A64281)
UNUSED AGT - AC...
2025 Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
5000 GALLON WATER TANK W/RELEASE VALVE (A64280)
5000 GALLON WATER...
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
