Price Check Just purchased MX5800
/ Just purchased MX5800 #1
jeremiah8808
Piketon, Ohio
Kubota MX5800
Hello TBN! I finally created an account after reading a ton of helpful advice on the forum over the past few months. The info I found here proved invaluable during my buying research, so thank you to everyone for creating this very useful resource.
So after my several months of research I decided on an MX5800 with the following options:
FEL with standard 72" bucket
Canopy
2 rear remotes, 1 with float detent
Top n' tilt kit
R4 tires with rimguard in the rears (adds 1100 lbs)
PFL3048 Forks
RTR1274 Tiller
BB2572 Box Blade
Right Handle (thanks to forum advice)
Price with 60 month 0% financing: $37,795
I'm currently waiting for delivery from the factory and will certainly be posting some pictures once I get my hands on it.
Thanks for reading,
Jeremiah
Piketon, Ohio
/ Just purchased MX5800 #2
Welcome aboard! The set up of your tractor refects your research. Good job.
/ Just purchased MX5800 #3
Congrats. If it’s not too late, get the 3rd function for the loader, and the 3rd remote out back so you have a hydraulic port open for the implement you may have back there.
/ Just purchased MX5800 #4
Congrats
You will be surprised at How much it can do
Mine amazes me with what it does for it's size.
/ Just purchased MX5800 #5
When you take delivery of the tiller operate it with it raised out of the ground and observe the sides from the rear while the rotor is turning. Landpride can’t seem to weld the rotor and stub shaft flanges true. Check yours before you put it in the dirt.
/ Just purchased MX5800 #6
I echo the suggestion for the 3rd function to be added before you take delivery.
And if you want the tires wider apart get that done too.
Thanks for all the replies. I thought about the 3rd function and grapple, but didn't really want the ones offered by Kubota/LP. I'll buy the 3rd function and install myself when I eventually get the grapple. Looked like an easy enough install. Same goes for the 3rd rear remote. I'm not a full time mechanic but can handle the basics, so I'm comfortable doing them on my own. I'll be sure to check out everything in detail before I take delivery as suggested.
I also own an 8 ton metal track excavator, so I'm debating between adding a hydraulic thumb to that rather than a grapple for the tractor. Auxiliary hydraulics are already plumbed on it. I don't see much need to have both.
/ Just purchased MX5800 #8
Depends on what you're grappling. If you want to lift things and pile them, or put them onto a trailer or similar, then excavator is excellent and probably more powerful and manoeuvrable. If you want to pick up tree branches or similar and take them somewhere, then the tractor will be way more efficient. And if you have need to do some of each, then maybe you need both. :)
/ Just purchased MX5800 #9
Congrats on the MX. We really like ours. And FWIW, I agree with the suggestion to get the rear wheels set out as wide as possible. But if you will be trailering your MX, make sure that the rear wheels of the MX will fit inside the trailer's fenders (our MX would not fit on the typical 78" deck but would with the 82" deck).
Yes, my property is hilly so wanting as much width as possible. My trailer is 82" between the fenders so I should be good to go.
/ Just purchased MX5800 #11
Yes congrats on your MX. I have a MX5200 & love it. All my previous tractors have had R1’s. The MX has R4. Pretty useless as soon as it’s muddy
Andy
/ Just purchased MX5800 #12
Newby......Soooo how do you check the hyd level. I have found the "sight" glass but it is impossible to determine if there is fluid showing.
/ Just purchased MX5800 #13
/ Just purchased MX5800 #14
I clean the sight glass and use a flashlight. It's still hard to see.
/ Just purchased MX5800 #15
The third function for the loader was on my 4240 when I bought it. Probably not a feature that I'd have been looking for. Shortly after buying the tractor I added a snow blade. Plumbing the third function with a couple hoses to the plow assembly to operate the left/right swing of the blade was really handy.
/ Just purchased MX5800 #16
That $37K price tag is killing me. The Kubota dealership here in Montana has a MX4800HST w/ FEL and heavy duty bucket, canopy, some extra hydraulics and whatnot priced at $34,600. By the time I add in a mower, grading scraper, grapple, and snow blower I知 bumping $50K.
/ Just purchased MX5800 #17
Back in February of this year I was quoted $28,300 for the L4701 with FEL. The third function was $1200. The MX4800 is a sturdier tractor than the L4701 so that price doesn't look too far off.
I would rather pay a premium and have confidence in my tractor than get a significant discount with a korean or indian tractor and wonder about longevity.
I actually got quoted on the L4701 and MX4800 the first time I went to the lot. The L4701 was $200 more expensive than the MX4800! The salesman quickly steered me toward the MX, saying the L4701 was a "*******" machine being the only L series on that frame, which would make parts harder to come by. Not sure how much truth there is to that, but the MX was a no brainer for me with the larger tires, lift capacity, more HP......and so on.
I was quoted at $28,200 for MX4800 with loader, $1400 to add the HD bucket, $1400 for 3rd function hydraulics, $580 for canopy, and $1000 for each rear remote. So your price of ~$34k isn't too far off depending on the hydraulic setup.
/ Just purchased MX5800 #19
Congratulations!!! :thumbsup:
KUBOTA LA535 FRONT LOADER ATTACHMENT (A64280)
KUBOTA LA535 FRONT...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
2019 Ford F-250 Ext. Cab Pickup Truck (A61573)
2019 Ford F-250...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
