Just pulled the trigger!
/ Just pulled the trigger!
So far the only attachments I have are my pallet forks, ratchet rake, and drawbar with a 2" ball if that even counts.
I'd love to have a grapple, but I think for what I do, forks will always be a "good enough substitute". Especially when I get "the thumb" on them.
With my filled tires and wheel weights so far the tractor is doing well without extra rear ballast. I moved some decking boards I had stacked up from one location to another with my forks. Over the course of moving that bundle (took a few trips) it felt a little sketchy. I'm working hard on saving for a box blade so that will serve as rear ballast once I get it.
I'm finding that with some weight in the bucket, and my RR angled right with the loader in float I can do a pretty job grading with it. It's a little more forgiving on this newb than trying to do some fine grading work with just the bucket. Yes, those are headstones . My wife's granddad was a mortician/funeral director (and used to own this property). We have blemished headstones and stuff like that everywhere .
I spread 120 bales of pine needles this past weekend. I hauled most of them on my 5x10 trailer and used the tractor to haul the trailer of needles around keeping them close by. I love being able to back up, raise the 3ph, I can lock the coupler down from the tractor seat, and start hauling. When I'm done let the 3ph down and drive off!
I ordered the skid plate and gauge/shim kit from BXPanded yesterday .
I picked up a boom pole yesterday for $60. It's nothing special! They had it listed for $100, I happened to have $60 cash in my pick, and they took it.
I don't know if I'll have much use for it or not. When I was pulling my diy drag around the yard, I was thinking a boom pole would be nice to allow me to lift it to back into a corner, or cross the driveway. I'm sure uses for it will arise over time, but for $60 if it only ever winds up being for my drag I'm okay with that. I also may find it's useful to make my 5x10 tilting trailer tilt in some situations. I've thought about moving the axle further to the back, retiring it from road use, and make it a yard dump trailer, of sorts.
40 hr update:
Gah-Lee I love this thing! Absolutely love it.
Fantastic little tractor for a homeowner.
/ Just pulled the trigger! #106
You need to loose that between the lift arms spreader and hitch ball and use the drawbar. The lift arems are not designed for that and eventually, you'll break something.
You have no idea what I'm pulling with that or why. I back up and hitch up to my empty trailer, or my 5x10 with not a great deal of weight on it without having to get off the tractor to hitch or unhitch. Works great for, example, pulling my 5x10 around to spread pine needles.
/ Just pulled the trigger! #108
Don't care either. Just forewarning you what will happen if you use it...and pulling anything with it puts the line of pull higher and the chance of upset higher as well.
Have at it but don't say you weren't warned.
230 hours on her now. Very much so enjoying having this tractor!
I use my box blade, rake, and grapple quite a bit.
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59906)
2016 FREIGHTLINER...
