Just Ordered My B7500!
   / Just Ordered My B7500! #11
dtmarion...
I also purchased from Carver and had to make the swap from the tractor trailer to the ground. I called a local garage that had a roll back truck. Fortunately the roll back truck had some ramps, but because of the low ground clearance of the MM, the FEL was needed to raise the front end up as I back down the ramps till the MM cleared.
I was a bit nervous as this was my first experience driving a tractor like this and then to have to back it down ramps while lifting the front end up. All turned out well though.
Since the truck driver had a cell phone, I was able to keep in close contact as he got closer to my deilvery (he had about 6 others to deliver before mine) which worked out well.
All in all, I have been pleased with my purchase from Carver.
dpm, Thats exactly the info I need. I too am new to this type of tractor and am a bit nervous about the truck to truck swap. Thanks for the info.
   / Just Ordered My B7500! #13
if the flat bed is 52 in. what is the height of the car carrier?mabey u can raise the back end of car carrier enough for a simple drive off the flat bed? right on to the carrier.or use a coupel of auto ramps to tranfer, just throwing idea's out there.
   / Just Ordered My B7500! #14
Here's another option Carver suggested to me when at we thought my tractor would be delivered by flat bed. Find a loading dock that will let you offload the tractor. A lot of them have ramps down to ground level. Then you can drive it onto the roll back or pick it up with your own trailer to get it home. Just some more options.
Jeff
   / Just Ordered My B7500! #15
What about building a couple of small ramps or someway of getting the rear wheels of the rollback truck off of the ground to level the two bed up to each other?
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2018 FORD EXPEDITION (A51406)
2018 FORD...
