Just ordered a new JD2320
   / Just ordered a new JD2320 #21
RalphVa said:
Congratulations. Hope they deliver it soon.
On the 4010, you have to remove one rear wheel to get the lower 3 ph gear out of the way of the hydraulic filter. Hope they changed things on the 2320 to eliminate having to do this, but it actually wasn't too hard to do.
Hope they fixed the under-seat switch on the 2320 to work with the seat up to use stuff like the shredder/chipper by just pulling the switch up. On the 4010 and 2210, they don't have this working. I jumpered a couple wires to make it work, but most times I just use a tension cord to hold the seat down.
Ralph
Dont worry the 4010 will not have an advantage over the 2320 - LOL
the Hydro filter is under the left floor board -tucked away nicely and easy reachable. The PTO switch for off seat operation is done differently on the 2320 - place the parking brake on and the drive in neutral. Select the rear only PTO option, and engage the PTO. Good for chippers and Post hole diggers
   / Just ordered a new JD2320 #22
No problem with my 72"RB on my 4110, which is the same as your 2320; only
yours is newer. Mine is a 2004 year. Also run a 72" FB for plowing snow.
I've never had an ounce of trouble with the tractor or the set-up. I have 89hrs on the machine. No sweat with 60"RB. All my tractor work is not just
snow. I cleared 3 acres wooded land with stumps and logs. You have a nice
set-up. ENJOY
elad
7046 (A50322)
7046 (A50322)
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
