Just Fixed a Battery with a Welder!
   / Just Fixed a Battery with a Welder! #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
This was the coolest thing. If I was a betting man I'd have lost a lot of money because I'd have bet 10:1 odds against this working.
My brother came over today with his two dead batteries from an 18V cordless drill, and wanted to use my welder for a minute. He'd seen some YouTube video about a guy re-furbishing a battery with a DC welder. I cautioned him that my welder is AC, and it doesn't go down very low. He said that he didn't have much to lose since neither battery was working. I hooked up the welder, but I made him go out in the driveway anticipating a spectacular explosion.
We clamped some welding rods (bare Ox/Ac type welding rods) to the positive and negative terminals of the battery using a bicycle inner tube as insulation between the rods and the clamps. We hooked the welder ground to the battery negative and then touched the battery positive lead a few times with another bare rod that we'd clamped in the electrode holder. Other than the typical striking arc, there was nothing spectacular.
He put the battery on a quick charge, and low and behold it charged great and ran the drill just like it should.
We fried the second battery when he stuck the rod to the battery positive for a few seconds.
Now I'm wondering what other batteries this would work on. I have three old lawn mower batteries that I'd like to refurbish.
   / Just Fixed a Battery with a Welder! #2
I have seen this work on Nickel Cadmium batteries like that used in the drill. The time I tried it by dumping a charged capacitor into a battery cell it only worked for a little while. The Nickel Cadmium batteries develop tiny short circuits inside some cells. The high current is supposed to burn the short open. Will it work on a lead acid? I don't know.
   / Just Fixed a Battery with a Welder! #3
It's not a very safe thing to do since NiCads are toxic. I used to rejuvenate NiCads. I would place the battery in a "bomb box" and monitor the rejuvenation with a current meter. I have not done this in the past 10 years because I figure that sooner or later, one will explode and contaminate my shop.
I am very certain that the technique I used would detonate a lead acid battery.
   / Just Fixed a Battery with a Welder! #4
If you open up the basttery packs you will find that they are made up of multiple 1.5v cells. Quite often one will be dead, the others OK. I have opened up a couple of batteries and come up with enough good cells to make one good battery.
I've also made up dummy batteries that have been connected to small recargable 12v power packs.
Sometimes just completely draining the battery (slowly) and recharging it will work.
   / Just Fixed a Battery with a Welder! #5
A long time ago I had a 'whisker trimmer' that generally helped nicads that were getting bad 'memory' effect.
Same principle.. high(er) voltage.. etc. burn them little shorts out.. but not enough to damage the cell.
havn't use done in years.. decades....
soundguy
   / Just Fixed a Battery with a Welder! #6
You do not need to use a welder. Most times any auto type battery charger will work if it is gonna work. All you are doing is getting the one cell that has dropped voltage to take a temporary charge so the auto sensing charger will cahrge the old battery. It usally only works once or twice.
   / Just Fixed a Battery with a Welder! #7
The automotive charger sounds a lot safer than a welder. I would think using a welder would have a greater chance of an explosion. I am going to have to check in to this it would be nice to get a little more life out of expensive battery.
   / Just Fixed a Battery with a Welder! #10
Has anybody had this work for a long time after the repair?
Nope, as I understand it nickel dendrites grow across the cell and zapping them just opens up a small gap. It usually does not take long for it to grow back. What might help is completely discharging the cell, not the battery, to zero volts and then recharging it at the C/10 rate until the temperature rises.
Most of the time I just replace the cell or all the cells in the pack. There are a few companies that will spot weld up custom packs for a reasonable price or you can buy cells with solder tabs and make your own.
   / Just Fixed a Battery with a Welder! #11
Yes, NiCd batteries suffer from "early" deaths due to what is commonly called "wiskers".
Wiskers form when a NiCd is left in an uncharged state, the longer they are left that way the worse it is. You can refresh them by applying a *slightly* higher voltage (3v typical for a 1.2V cell) from a source with a good charge that can deliver a few amps safely. The higher voltage will allow current to flow and the high current will burn the wiskers out (much like a 12v light bulb in a 24v circuit).
If the pack is treated well afterwards by cycling from 10% SOC to 100% SOC and back and NOT left partially charged, you can get good life back. In my recent case, 3 of the 5 cells in my MAG were "bad", I shocked the pack from my 12v motorcycle battery using a 20A fuse to prevent anything bad from happening. I got two of the cells back but the third only lasted a week and it failed again and could not be brought back.
So, the method DOES WORK but is not a 100% fix for every situation. If you have multiple packs and can try one cell at a time your chances are very good. If you have no "extra" cells and are trying to get a pack back with multiple bad cells, your chances are not as good but it can work!
Good luck!
PS: DO NOT try this with NiMh or LiOn cells!!!!!!!!!!!!!
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
9000 (A47477)
9000 (A47477)
