MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 63,274
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Well, the PT180 is $361 per HP and the 422 is $409 per HP, and the 425 is $528 per HP.
MossRoad from 2001 said:Re: Power Trac PT425 Quick Change Challenge
The 418 and 422 use Robbins engines and have 18 and 22 HP respectively. The 425 uses the Kohler Command 25HP engine.
The 418 does not have a hydraulic oil cooler and fan, the 422 and 425 do.
The 418 and 422 do not come standard with ROPS. The 425 does.
Price difference:
$6000.00 for PT418
$7000.00 for PT422, 4 more HP and hydraulic oil cooler.
$8000.00 for PT425, 7 more HP, Kohler Engine and hydraulic oil cooler ROPS and canopy.
Every one that I talked to are happy with the Robbins engine except one landscaper, who said that his 18HP died at 300 hours. Did not tell me why it died. I've always been partial to Kohler and there are several good places around here to get them serviced under warranty if needed. I looked at it this way. The gain in HP between the 18 and 25HP units is over 33%. The price difference is also a gain of 33%. So I am paying the exact same amount for each HP and I get the ROPS, canopy and hydraulic oil cooler free!( is this great math or what?)
I'm dying to know what you decided? ;-)Here's a post I made back in 2001 where I justified the cost of the 425 to myself...
I had a zero turn, and blew out one of the transmissions after about 5 years. It would have been $1600 to replace, so I ended up getting the garden tractor. That was my first zero turn, and because I felt it left me down, I won't be getting another. I know it could have been a fluke, but I felt that an expensive zero turn should have lasted me longer than 5 years.Absolutely. You will be disappointed in the mowing performance of the PT180. And there is a significant difference in other capabilities (such as lift capacity and height).
And if you need to do rough field mowing, the PT422 will barely cut it.
In terms of speed, unless you are on slopes, the PT isn't going to come close to matching the speed (and cut quality) of a zero turn mower. The PT is a swiss army knife. It does a lot of the things, just not all of them well.
I got my tractor, she got her car. :laughing:
