Oil & Fuel Just bought a Belarus 250AS
/ Just bought a Belarus 250AS #21
I've never heard of tying the two wires off the plug together.
.... then to a switch then to the battery.
He demanded I do it that way after he had to replace burned diodes or something from the first time I used it. I did have it like you said and the smaller black wire just cut off. Still I suspect the real reason it burnt something in the ALT the first time is I think there was still stuff hooked up on the orginal regualtor that was running through the key switch. I'm using the original key switch to start now but I cut all the other wires coming out and just found one afterward that would switch with the key to go from the battery to the solenoid small terminal.
/ Just bought a Belarus 250AS #22
I found a decent wiring diagram to help in the re-wiring. I really don't care for the micarta boards with little wires wrapped all around. I straight-fused one circuit years ago with one strand of copper wire from a #10 AG wire. That may be why a couple of things burned up over the next few years.
/ Just bought a Belarus 250AS #23
Ebay seller CALTRIC sells the reduction drive starter for the 250AS for $155 with free shipping. Got mine in last week, and the results are astonishing.
He must have just raised his price - now it's $185.
/ Just bought a Belarus 250AS #24
Ahh "caltric" I thought the logo was "centric"
That was the one I was going to buy first but they didn't answer my email about the nose differences they mention. It was a little more than the one I got.
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2015 LeeBoy 8510C Asphalt Paver (A61572)
2015 LeeBoy 8510C...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
Zero Turn Mower (A59231)
Zero Turn Mower...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
Lot 602 (A62613)
Lot 602 (A62613)
