just bought a 4530
/ just bought a 4530 #1
tsavoy01
scott la
mahindra 4530
well hello people, im new here, i just bought the 4530 with FEL, so far so good only have about 8 hours on it and the **** seat came off :confused: any one else had this problem? tractor runs great !
/ just bought a 4530 #2
LOL..Welcome to the forum..Yeah had the same problem with mine at about 65 hour mark..Used lockwashers ,tightened the sucker down and have not had any more problems..Only other problem I have had was the return fuel line started leaking .dealer replaced with no more problems.I love this tractor...
How do you get to that seat? I've took off the front sheet metal and it's a pain in the butt to get to those holes.
/ just bought a 4530 #4
Welcome from sunny (and HUMID) central Florida!
Congrats on your new toy, err, equipment!
:welcome:
/ just bought a 4530 #5
tsavoy..
Youre right the seat's are a pain in the butt..lol,If I remember correctly I pulled the seat along with the piece of 1/4" square plate that the seat actually mounts to.Flipped it all over as an assembly rebolted the seat to the plate(WITH LOCK WASHERS ...like it should have had in the first place)added a couple of drops of blue locktite as an added precaution. Then reinstalled the plate steel back to the tractor..
Good luck,and again welcome to the forum
Sean
Yea had to take off some sheet metal, but I got the nuts on! So far every thing is good, I wonder what's the best size cutter and disk I can pull behind that thing ???
/ just bought a 4530 #7
Good deal, welcome to TractorByNet.
The cotter pin on the hinge of my 3016 seat failed before it hit the 5 hour mark. I went back with a flat washer and a heavier-duty cotter pin. I also had to tie the female portion of the seat belt up to where I could grasp it; it kept working it's way into the darnedest places.........now, I reach for the PTO lever and its right there.
/ just bought a 4530 #8
/ just bought a 4530 #9
tsavoy..
I run a 6 foot hog through real heavy grass/brush and I dont even know it's there..I also have run a 10 footer that I borrowed from a neighbor just to see what it would do.The 10 foot did fine in low range 2nd..While I wouldnt win any speed record's with the 10 it actually did ok.. As far as disc...The only thing I have is an old Ford Motor Co 16x16 that it pulls with ease...
Ok that sounds good! Ill probably end up buying a 6ft, I have an old 7ft bushog I might try, it's on heavy SOB, it should lift it I'm hoping. By the way, what is a 16x16 ? Is that the width and length ??
/ just bought a 4530 #11
16x16...16 discs,16 inches tall..I would try that 7 foot hog out.I have been wanting to find one to try on my machine to see what it would do.They say figure 5 horse of pto power per foot on the brushhog. the 4530 is rated at 35 hp max,so 7 footer would be your max size..
/ just bought a 4530 #12
An 8' dual spindle usually runs just as easy as a 7' single spindle unit.
/ just bought a 4530 #14
Galen
Thank's, never really thought about it ..But it make's sense...
What do y'all mean dual spindle? Are you talking about a cutter with two gear boxes? Oh and another question, how wide is that 16x16 disc?
/ just bought a 4530 #17
16x16 is roughly 5 1/2 feet wide by 6 feet
Generator (A64553)
Generator (A64553)
2015 RWF Bron HSII Cable Plow Attachment (A68183)
2015 RWF Bron HSII...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
PORTA POTTY (A68842)
TEST YOUR BID BUTTON! (A65056)
TEST YOUR BID...
2022 ASV RT135 MAX-SERIES SKID STEER (A65056)
2022 ASV RT135...
