Just another junk chainsaw
/ Just another junk chainsaw #861
But for limbing I prefer my MS241CM. It's got more power and cuts faster but it's still light enough for me to limb an entire large tree. Unfortunately Stihl no longer sells them in the US.
I really wish they kept selling it here, I had settled on it as a limbing saw until I saw the sales numbers. And sure enough it was pulled from the market. Most say it is a good saw that just never got traction in the US product line.
If you like the 241 pro grade just by the 261 type 2 or 3 now. They same weight basically with 50cc power.
IMO why they got rid of the $600 cost 241. The first 261 out with plain clutch cover was the pig weight wise.
You can put the 241 bar chain set up on a 261 with rim change etc. Fluid amounts held not much different either.
Mix wise just under 4 fluid ounces at 3.8 of fuel more held by 261.
Bar oil just a half fluid ounce .5 difference by stihl specs.
Here is my new $100 limber. Copy of the Zenoah Redmax 3800 I used to have. Thought why not try it out and see. Joncutter G3800. 38cc
They need a muffler mod to wake them up just like OEM did.
Over look the 25:1 they put that on all of the clones. I run 40:1 like I do in everything. Just tune for it.
/ Just another junk chainsaw #864
Stihl still makes it they just change the numbers and letters around like all equipment manufacture's do, they just cant stick with one number. Same with Husqvarna or tractors, over the past 20 years Husky lucky there's all kinds of numbers and letters, but I think the 550xp is one of their longest model numbers since 2011-ish, now that they have that model number, stick with it and dont change it, all this changing number stuff kunfuses me........
/ Just another junk chainsaw #865
View attachment 680153View attachment 680151View attachment 680152
The new rule at my house is no new saw less it has flip caps, I absolutely love flip caps, best improvement since slice bread and right now I prefer Huskys caps are then Sthl's, but
thats a on going time/durability test..........
Hate stihl flip caps. Have a fix for those over engineered stihl designed ones. :laughing:
Love husqvarna flip caps. Screw in like caps should be. Can use a flip cap or old school style in saws. They got it right. :thumbsup:
/ Just another junk chainsaw #867
The stihl flip caps can be a bit fiddly to get in but I like that they lock down positively. With screw in caps of any type it's possible to not screw them in hard enough and end up wearing a tank's worth of premix or bar oil.
If you hate them there's a number of outfits offering screw in replacements.
/ Just another junk chainsaw #868
View attachment 680158View attachment 680159
Who makes those? I do not mind the flip caps, kind of like them except for one saw. I think it is a bad or wrong cap and I would not mind trying one of those. How many different sizes are there for Stihl?
They never made the small ones. So just the one size.
There was 2 company's making the stihl ones. But 1 US reseller went under with the one style. So I only know of the proline ones now being sold out of TX.
2 on the right non flippy. Only 3rd one from left is left to buy now the proline in TX.
One owner has them on all his flippy stihl saws.
/ Just another junk chainsaw #870
Can you or anyone here recommend a good small saw for limbing? I have a couple of older Huskys for the big work but having trouble working them in the brush.
I bought a new Stihl MS-180 a month ago, it barely runs. Dealer did a new carb and at least now I can use it but it runs too lean to be of any use to me.
It is a tough little saw as I've thrown it as far as I could about 5 times now and it hasn't broken.
The dealer DID try to discourage me from buying it but the $200 price tag was intriguing.
My best guess is to buy an older used, less than 3 cubic inch saw that has a good track record.
I should have never gotten rid of my old Jonsereds 621.
Thank-You.
I needed a limbing saw and was walking through my saw shop when I saw this top handle stihl. It had a tag that said, special order sale. Went up and looked into it. A tree guy ordered a ms151 tc and never came in to get it. THey were selling it for 299. Regular is 600 with a bar and chain. I bought it right then and there. It is not Mtronic and the carb is fully adjustable. Score.
It's the lightest weight pro saw stihl makes at just over 5 pounds. It's a little ripper and is so light a person never gets tired using it.
/ Just another junk chainsaw #871
View attachment 680185View attachment 680186View attachment 680192
You ever have any old big bore saw come through your shop? I have two trees I need a big saw on, but I would rather get something old just to see how the old guys did it.
/ Just another junk chainsaw #872
I liked Husky flip caps so much I bought some for my Echo 501p, trouble is the Husky seals from the sides of cap while Echo seals from top of tank and under cap, I had to try several different O rings to get the oil from leaking out of tank, luckily I had one that worked. The gas tank seems to seal, so far, I didn't notice this issue til I bought the extra caps so when doing this red-neck engineering one should first know how the cap seals, all's I went by is if the cap screwed in, I almost screwed up......
/ Just another junk chainsaw #873
I did that last year on my Echo, I got tied of how hard the oil cap came out for refills so I stopped tighten it so tight, next thing I knew I had oil soak insulated Carhart's.....
You wouldnt believe the story's I get from owners of the stihl flip caps. Wearing the bar oil or the mix, because they didnt seat right. heck I had it happen on just saws I work on. Yes I own a bunch of saws with stihl flip caps. Chit just happens sometimes. :laughing:
But that is why we have choices like ford chevy dodge etc. Everyone can choose their likes.
Give me screw in cap with a flip. Heck even echo went to a screw in with flip too sort of like the husky in pic below.
video http://chainsawrepair.createaforum.com/echo/echo-flippy-caps/msg86382/#msg86382
/ Just another junk chainsaw #875
Not making sure your Stihl flippy is secure is one of those once in a lifetime experiences. Never do that again. Well, maybe twice.
/ Just another junk chainsaw #876
I was wrong the one I bought is a MS170, yes they wanted $600 for 151, the dealer told me that is the one I should buy because it's fully adjustable.
I told him for $200 I'd try the cheap one and if I wasn't happy I'd hurl it through his office window, looks like I lied.
He did install the medium sized jet and said there is one more richer size. I was in the woods all day cutting logs today and I didn't bother to take the POS with me.
It's very frustrating to hear a saw run that lean. That's my first and last Stihl saw. My first job out of high school was working on saws at a dealership that sold Stihl and Jonsereds; I remember the 031 and 041 were nice saws back then. I'll stick with Husqvarna next time but because of Covid they were all on backorder.
I had one of those light MS150. It's the one before the 151. Pricey freaking saw, must think their gold.
Carb is adjustable if you bypass those freaking epa stops they put on them. Mine was to lean from factory so I fixed that crap. Needs muffler modded too. Like a small straw for exit. Open it full length like shown.
The echo 2511 is lighter then the 150 151 and comes in top handle and rear handle for a fraction of the stihl cost. Think the little echo's around 5.7lbs
/ Just another junk chainsaw #878
"Carb is adjustable if you bypass those freaking epa stops they put on them" My Echo has those on its carb, guess it's so one wont screw jet in all the way, could be one plus for Husky and Stihl auto tune......
/ Just another junk chainsaw #879
View attachment 680546View attachment 680547View attachment 680548View attachment 680549View attachment 680550
Why didn't you just remove the limiter caps?
The one was a metal tab. Drilled it out. Other was just a plastic tab. Trimmed it off. Easy peasy.
It's not those red plastic caps. They are metal in newer one
Why waste time pulling the metal cap inside there to do the same thing. I was going to take the tab off anyway. ;)
Just like this 251 carb with 2 metal caps. Just to easy to drill the freaking tab off and never have to pull the metal caps.
(1) KUBOTA 8 LUG RIM (A64280)
(1) KUBOTA 8 LUG...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
UNUSED AGT YC-S6G SAWMILL (A64281)
UNUSED AGT YC-S6G...
Great Dane Van Trailer (A63689)
Great Dane Van...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
