Just another junk chainsaw
/ Just another junk chainsaw #2,901
Thats Canada stock.
No USA stock at Farmertec right now.
Got to watch it there. Have warehouses in China. Then USA, Canada and Australia warehouses too.
If in USA. Hockfire saws Scotty is a dealer south of me. He has the G2511 Farmertec ones for 99 too. But sold out.
He also has the V-modest one for 129 in stock. 6 left. V-Modest 2511
I got both and same saw different colors.
Scotty goes through the saws before shipping so no surprises like you get sometimes.
Another good thing he is here too and does warranty work for them. @Hockfire Saws
Good to know,
Ordered the V Modest 2511 from Hockfire
THANKS XYZ
/ Just another junk chainsaw #2,902
Wow just looked at the thread about the 2511 Echo saws, where you mentioned the pipe mod- once I get a few tanks through it going to build up a copy pipe for the copy saw.
That graph shows an impressive power increase on the real Echo 2511's.
Those clone ones come with a lot better muffler with small pipe already. IMHO no need for a Egan pipe or a PSS V2 cnc muffler on those clones in stock form.
I tested 3 out and those were 1 and 2.
They are mainly needed on the stock oem muffler on 2511. Stock oem mufflers are trash epa BS.
The clone muffler is good to go already IMHO.
/ Just another junk chainsaw #2,904
I forgot about how the china saws generally already have opened up exhaust, One less thing to need to do then.
Worked on the plastic case Husky 350's yesterday, one the darn decomp was stuck open on the closed port one and the other the top cylinder bolts had loosened - at least the modded mufflers are not falling off.
Some pics of clone fully open smaller pipe muffler. The PSS V2 cnc one and Egan pipe. IMHO no reason to replace the clone muffler unless you go wild with porting one. Then Egan pipe #1.
I tried the WCS cnc one in this test and it was only better then the stuffed up oem muffler. So I wouldnt even waste my money on that cnc one.
Pulling out some of my old stock 6 rivet tips for a guy wanting better back to the newer 4 rivet ones.
Helping a guy in my group to modify the small husky flip cap for the use of oil cap on a 346.
I had used a goofy file which is no longer made between the threads.
I was able to match up a tiny 1/8" file I use on 1/4" mini micro. Hopefully works for him.
You need this and a flat file to mod them for 346 oil cap use.
The 346 etc oem clutch cover decal on eBay. USA dealer.
Is just like the ones from overseas I had to order last year.
So good to go.
Dealer I used to get from wont sell anymore since he collects saws.
Locals 2100 2101 I built 4 of them for him out of around 10 he has. I have tuned and ran all of them testing for him.
21's are cheap around my area.
Not rare at all. Plenty of them out there.
Ive sold alot of poulan 4000 64cc saws. Built like tanks and last forever.
Now this one is a rare saw. Not because it is a Poulan 4000. But because it has the optional full wrap.
Full wrap one I have only seen once.
In the later color scheme too.
Back when we could make our own stuff.
The then rich got greedy.
Big boys stihl 084 and dolmar 166
@Paystar just repost it.
I found it. His post by mudsomething -
It is simple to test for ethanol. Here is how the pilots can do it:
Recently a member of the aviation club, Gilbert Pierce of Germantown, Tenn., sent us the description of how he tests for ethanol using a few drops of ordinary food coloring:
“While driving 20 miles into Mississippi to get ethanol-free gasoline for my airplane I was contemplating what must be in the blue dye that is in the Quick Check Solution kit. It occurred to me that what ever it was had to be water soluble so it would mix with the ethanol. I always check the suppliers of ethanol-free fuel before pumping any gas as I have been lied to about it. Anyway, the test kit that you add water to is a hassle and takes a few minutes to settle out. The blue Fuel-Check works great but is expensive. When I got home I got my wife’s red, blue and green food coloring out; it’s water soluble. A quick check with pint jars of ethanol-free fuel and adulterated fuel indicated that a drop of any color food coloring will dissolve and turn the adulterated fuel the same color as the food coloring. Putting a drop of food coloring in pure gasoline, the drop just goes to the bottom of the sample and rolls around there as little globules. Now I just carry a bottle of inexpensive and readily obtainable food coloring and a quart glass jar – it’s easier to get a fuel sample into – and have an instant indication of ethanol free fuel or adulterated fuel.”
Remember, always test every batch of gasoline purchased at any location other than an airport — “Let the buyer beware” !
@Rovcketman357
NOS 655 Boost Port. ;)
I was never really cared for the 655 myself or the other pioneers of that series. But they do have a cult like following for the 100cc saws.
Which I like so makes stuff easy to sell.
Have a used set here too. It needs help though had scored at one time.
/ Just another junk chainsaw #2,917
You have a 655 BP cylinder and piston in your possession?
NOS is sold now. Only the used set that was hurt.
Cant find my pics of the used one.
/ Just another junk chainsaw #2,920
So you have a used 655BP cylinder and piston in your possession.
You selling?
