Junkyard hydraulic auger
   / Junkyard hydraulic auger #1
moparrob
SW Idaho
2008 Kubota M59
While perusing the local junkyard (I do that all too often) I saw a scrapped digger derrick pole setting truck with a big hydraulic auger. Picture an International truck which puts in power poles. Every bit of it is available priced by the pound. I looked up the model number of the derrick body (Altec D1090B B) but couldnt find any specs on the auger motor. I want a hydraulic auger that I xan use on my loader or backhoe but I have a low flow tractor (Kubota M59).
Anybody here have any knowledge or experience? Its a big backache to haul it home, fabricate mounts and plumb it in to only get 5-6 rpm. The hoses connecting to this thing are way bigger than any of the hydraulic hoses on my tractor.
Im putting in a large driveway gate soon and this would make life much easier, especially with all of the fence I need to build and trees my wife wants to plant. Ive already used up 3 on-man gas augers but buying a proper one meant for my machine is more than I want to spend at this point.
   / Junkyard hydraulic auger #2
Ahh, the dangers of junk yard visits. ;)
Good luck with your search. (y)
   / Junkyard hydraulic auger #3
That's going to require far more flow than you have. Basically worth the "scrap price" as far as use.
Attached is a link for a "pole truck", a little into the article, it says the truck PTO / hydraulic pump generates 72 GPM to turn the auger.
That's probably why the hoses are so big.
Yeah probably uses a lot of the engine's power pushing a big pump like that. It also extends and raises the boom, crane winch, pole grabber claw, outriggers etc.
Darn. Figured it would be too big.
UNUSED FUTURE POWER TROWEL (A60432)
UNUSED FUTURE...
1993 Military Potable Water Tank Trailer (A59228)
1993 Military...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
32in. Tilting Bucket Mini Excavator Attachment (A59228)
32in. Tilting...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
