Jumping from skidding tractor
/ Jumping from skidding tractor #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I was talking to a friend from Yosemite Ca. yesterday and he was telling me about his accident. He was driving his Kubota down a slope (in 2 WD) and the rear tires good on some dry oak leaves and started to slide sideways. He managed to steer into the skid and straighten it up but applying the brakes just seemed to speed it up. It continued to slide down the hill and when about 15 feet from a barbed wire fence he decided he had to get off. On the other side of the fence was a 15 foot deep swale. He made it off the tractor without getting hit by the implement on the 3 PH but ended up make a back roll down the slope. He noticed his ankle painfully when he tried to stand up. His tractor went thru the fence and ended up at the bottom of the hill resting on the FEL and rear tires with the front tire off the ground. The seat had flipped forward with so much force that it impacted the tilt steering wheel with enough force that it cracked the plastic on the instrument panel. He said for sure that if he had stayed with the tractor he would have been seriously injured or killed.
He managed to hobble down the slope and kill the engine which was still running.
In the heat of the slide, he said he didn't even think about just lowering the rear implement or the FEL to stop the tractor. All he could think about was how he was going to get off without getting ran over. Funny how the mind sets on one task and forgets the obvious answer to a problem. If he had just dropped the FEL to the ground it would have stopped the tractor. He didn't say what implement he had on but he said if he had lowered that it would have stopped it also but he was only thinking of how to get off the tractor before it went thru the fence and into the deep ditch.
We should all start practicing a what if scenario in the back of the mind when doing any tractor activity that might become life threatening (or any other possible dangerous activity) and have a response ready just in case. When working construction, every task had to be evaluated by the supervisor and crew and discussion of "what if" and how to prevent or respond to any foreseen emergency with emphasis on PREVENTING an accident.
A good thing to do when working on your tractors or with other dangerous tools.
Oh, he is still being evaluated by the doctors to determine what damage was done. They did find a stray bone fragment in xrays but haven't determined where it came from. He is in a temporary cast presently on that leg and more MRI and Xrays scheduled for Thursday to determine where that bone fragment was splintered off from.
/ Jumping from skidding tractor #3
I did the same thing once! I didn't have a fence to go through and the drop was only about 6 feet so I rode it out. Now when I approach a steep grade the front wheel assist gets engaged.
/ Jumping from skidding tractor #4
thanks Gary, good reminder. hopefully his recuperation is speedy. it is this kind of scenerio that keeps me evaluating the more compact BX25D as my first choice. I can't "jump" ... hmm.
/ Jumping from skidding tractor #5
I live in hilly terrain as well. Unless I am on a paved surface, mine stays in 4wd for this reason. I once forgot I had it in 2wd but was fortunate to be quick on the loader and drop it. After leaving 3 skid marks that day, my policy changed. Yes, 3 skid marks but I was again fortunate and the 3rd washed out and I didn't have to sacrifice that pair of underwear.
/ Jumping from skidding tractor #6
Good advise and reminder, Gary. Situational awareness.
Dry oak leaves on a slope are hard enough to walk on and stay upright.
Ejector seat not an available Kubota option? :)
Well my friend is 70 years of age and still managed to jump, but the bones are just too brittle for that kind of activity. My wife's sister just had surgery on her knee which had one side of the lower bone(tibia or fibia) fractured when our dog knocked here down while playing with her dog. Those two German Shepherds see nothing but each other when chasing and roping with each other and our dog weighs 115 pounds so he can do some damage when he runs into you. Her dog did the same to me a couple years ago and the knee still pains me.
/ Jumping from skidding tractor #8
Gary - either way, I still can't "jump" clear :) and we have a big attitude dog, and a big dog (130 lb growing puppy).
/ Jumping from skidding tractor #9
4wd is not the end all be all, I was pulling a wagon down a snowy slope two years ago, (chains on the front tires because it was cheaper than the rear tires) anyways, the wagon started pushing me in 4wd so I dropped the loader. That slowed me down for a second until the rear end came loose and I ended up 'cracking the whip' so to speak with the wagon. I thought I was done for. Long story short, I chain all 4 tires in the winter now! :thumbsup: I was buckeled in and had no plans of jumping whatsoever. Good thing to because it came around towards the doored side of the cab.
Had a similiar instance with a 2wd tractor and a hay wagon many years ago, We were in a hurry trying to beat a incoming storm so I took the short cut down over the steeper part of the hill. Its somewhat entertaining looking back at one tire spinning forward and one tire spinning in reverse. I just kept the nose pointed straight down hill and rode that one out. Always took the long way after that one! Never thought about jumping then either.
/ Jumping from skidding tractor #10
eye-opener! Gary, thanks for posting!
I always think I will "jump" but all it takes is a little change and your plan doesn't work….
/ Jumping from skidding tractor #11
Seems to me the safest place for him would have been in the seat with his seatbelt on, as long as there is an ROPS in place. Yes he would have faceplanted the dash, but that is still better then ending up under a tire.
I fully agree though that having a "what-if" plan is important. My dad taught me to be always planning an escape route when he taught me how to drive, and it has saved me at least a couple dollars in scratched paint over the years. I plan to teach the samne to my kids when they come of age to drive.
Riding out a slide is the best way as long as there is a clear landing spot at the bottom. A cliff or deep gully in your path puts a whole new light to the equation. I don't wear my seat belts on any of my tractors just for this reason. A ROPS may protect you but if you go in the water, it may just be your executioner. 50/50 on good or bad results of seat belt use. In a car, I always buckle up but not on my tractor. Same with my buddy, if he had been buckled in, he likely wouldn't have had time to unbelt and jump and a fifteen foot fall with sudden stop at the end would have done him some damage even if buckled down,(NO AIRBAG to protect the upper torso on the tractor)
/ Jumping from skidding tractor #13
just glad he's recovering
/ Jumping from skidding tractor #14
I agree about the drop at the bottom. Its a little more difficult getting out of a cabbed tractor than an OOS one is. Either way, I'm pretty sure it would be at the last possible second before I'd consider jumping.? but I don't know, never made that choice yet!
2022 Dodge Challenger Coupe (A59231)
2022 Dodge...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
