jump start
/ jump start #1
ch1ch2
Veteran Member
DFW, TX
IH 584, NH TC33DA, NH TN95A
I see lots of pages of where a xx tractor will not start. Turn key and nothing.
I was thinking (my first mistake) but, I could not think of a starter which does not have the pos battery going straight to it. I can not think of a starter that does not have a control circuit wire going to the starter.
Power to the control circuit allows the battery to spin the starter.
MY question is...are there any starters where this is not the case?
I posted this and then thought of a lawn mower. It on has one big wire going to it from a solenoid. Had to edit to add this.
I am thinking of tractors mainly.
/ jump start #2
Some tractors built in the 60's and before were positive(+) ground instead of negative ground and had a manual starter switch instead an electric solenoid with the (S) terminal you referred to. Older Ford tractors had starter gear engaging flywheel from inertia of armature spinning IE starter only had battery cable attached no other wires.
/ jump start #3
For the most part, you're right. The basic principles you describe do indeed apply. Most tractor starters do have a battery positive cable and a signal wire from the starting/key switch circuit. At least with "modern" tractors. There are still a few older units, as Jim mentioned, but they aren't usually discussed in the "my tractor won't start" threads, except maybe for some older Fords with the isolated solenoids.
It is rather interesting that so many individuals don't seem to grasp this and make the simple tests first before condemning and replacing starters, batteries, cables, switches etc, then when all that fails, finally start asking questions. Go figure!
/ jump start
That is what I was thinking.
My first thought is to determine if it is the starter/battery or control circuit before looking at anything else.
213091 (A64276)
213091 (A64276)
2022 EZ-GO ELITE...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
1998 Toro Groundsmaster 223D 52in. Commercial Riding Mower (A64194)
1998 Toro...
2009 Ford F-350 Mason Dump Truck (A64556)
2009 Ford F-350...
