jubilee steering adjustments
/ jubilee steering adjustments #1
donet
When I drive my Jubilee on the road the steering wobbles .Is there an adjustment that will stop this.All the rod end are good with no play.:confused2:
/ jubilee steering adjustments #2
there is a adjustment on the end of the pitman arm shafts that you can screw in and tighten the pitman arm shafts free play but thats about it
/ jubilee steering adjustments #3
After many decades, the sector gears usually have more wear at the center of their range than at full lock either way. So with the sectors adjusted to steer smoothly at full lock both ways without binding, they will have excessive backlash at steering center.
Setting the toe-in and keeping matched tires properly inflated can help.
/ jubilee steering adjustments #4
in addition to what was said.. do you have any up / down play of the steering wheel.. or does it screw in / out of the column.. if so.. it needs thrust bearings..
soundguy
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2024 JCB 35Z (A60462)
1995 John Deere 7400 (A60462)
1995 John Deere...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
