jubilee steering adjustments
/ jubilee steering adjustments #1
donet
When I drive my Jubilee on the road the steering wobbles .Is there an adjustment that will stop this.All the rod end are good with no play.:confused2:
/ jubilee steering adjustments #2
there is a adjustment on the end of the pitman arm shafts that you can screw in and tighten the pitman arm shafts free play but thats about it
/ jubilee steering adjustments #3
After many decades, the sector gears usually have more wear at the center of their range than at full lock either way. So with the sectors adjusted to steer smoothly at full lock both ways without binding, they will have excessive backlash at steering center.
Setting the toe-in and keeping matched tires properly inflated can help.
/ jubilee steering adjustments #4
in addition to what was said.. do you have any up / down play of the steering wheel.. or does it screw in / out of the column.. if so.. it needs thrust bearings..
soundguy
2024 JCB 35Z (A60462)
Bobcat 873 (A55272)
Bobcat 873 (A55272)
Caterpillar 920/930 Wheel Loader parts and service manuals (A63117)
Caterpillar...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
