Jubilee Drum
/ Jubilee Drum #1
mwilliamsmd
Kalamazoo, Michigan
1953 Ford Jubilee
Hello, new to the forum. Doing my first ever restoration, Ford Jubilee. Right rear drum and hub is original (4 screw). All four are seized. Tried penetrating oil and shock. Ordered a drag link socket but is too wide/thick won't fit in slot. Not a welder so welding a nut is somewhat out. Any other tricks out there? Any idea appreciated.
/ Jubilee Drum #2
Use a small propane torch to get the screws hot enough to melt wax. Touch a candle to what ever exposed screw parts you can. Head/threads etc. Do this several times. Each time taking a large punch and hammer hitting the area around the screw. You don't need to hit it hard. You just want to send a shock through the area to loosen the rust. If you have a punch you can grind to fit into the slot on the screw that would be a good place to hit too. If you do this several times over several days the screws will become loose enough to turn out.
/ Jubilee Drum #3
:welcome:
To the TBN forum mwilliams. Glad that you joined.
So, are you a Medical Doctor (MD)?
/ Jubilee Drum #4
Best penetrating oil I have used is 50/50 mix of ATF fluid and acetone. Get nut hot, then flood - be sure the flame is somewhere else. Keep it soaked for a few days.
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
(2) New 14-17.5 NHS tires w/ fluid on 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
John Deere 4039TF001 (A64127)
John Deere...
