joystick switch knob for elec/hyd. valve
   / joystick switch knob for elec/hyd. valve #11
I also used an ATV winch switch. most are water proof two position momentary rockers that are perfect. Mine came with a handle bar mounting bracket for about $25.00 :thumbsup:
   / joystick switch knob for elec/hyd. valve #12
Mine is a rubber coated water proof switch I got in the kit from Fasse. The kit isn't much more than the switch, the electric/hyd valve and a pre-made wire that runs between them (plus a fuse). I had to extend the wire for my install, so I didn't gain much from it other than having the plug already on one end. You can barely see it in the pic just under the control stick knob, to the left (the sort-of rectangular black thing). Not a great angle on it.
attachment.php
   / joystick switch knob for elec/hyd. valve #13
The research I have done leads me in the direction of making my own, but after seeing the prices for some of these handles a JD LVA13698 is priced at around $172 and has 3 buttons on it all thumb operated. It could be made to fit most any control valve with a little fab work. It is the control handle that fits a JD 110 TLB (Construction Equipment). I hope this might help
   / joystick switch knob for elec/hyd. valve #14
Seeing how this thread is 6 YEARS old I'm sure they have it figured out.
   / joystick switch knob for elec/hyd. valve #15
I used the JD Grip for mine and bought the parts "piece mill" and got away about $100 cheaper than that (and I stole the idea for doing that from someone else) - My build thread is over here:
http://www.tractorbynet.com/forums/customization/358086-kioti-ck-35-3rd-function.html
One would hope but there are some slow learners out there. Lol
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2008 Freightliner B2 School Bus (A55852)
2008 Freightliner...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
