Jun 21, 2021 / Joystick stuck in float position #1 M melgibson Bronze Member Joined Aug 26, 2007 Messages 88 Does anyone have a fix for this? Thanks
Jun 21, 2021 / Joystick stuck in float position #2 Thomas Epic Contributor Joined Apr 6, 2000 Messages 32,624 Location Lebanon,NH. Tractor Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower. More info....stuck in float mode etc. ?
Jun 21, 2021 / Joystick stuck in float position Thread Starter #3 OP M melgibson Bronze Member Joined Aug 26, 2007 Messages 88 Joystick is all the way forward and won’t come back to normal lift function
Jun 21, 2021 / Joystick stuck in float position #4 Thomas Epic Contributor Joined Apr 6, 2000 Messages 32,624 Location Lebanon,NH. Tractor Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower. If you have quick disconnect for the front loader remove them might help. Could always spray WD40 on to spool might be just dirty.
Jun 21, 2021 / Joystick stuck in float position #5 RickB Super Star Member Joined Sep 18, 2000 Messages 15,190 Location Up the road from Dollar General WNC Tractor Just a Scag Take the detent housing off the valve body, clean and lube it.
Jun 21, 2021 / Joystick stuck in float position #6 Xfaxman Super Star Member Joined Feb 8, 2013 Messages 13,322 Location Guthrie, OK Tractor Toolcat 5610 G - Bobcat V417 - TORO+Loader melgibson said: Does anyone have a fix for this? Thanks Click to expand... What Series Toolcat is it?
Jun 27, 2021 / Joystick stuck in float position Thread Starter #7 OP M melgibson Bronze Member Joined Aug 26, 2007 Messages 88 Update- it was the lift solenoid coil. Thanks
