Joystick Help
   / Joystick Help #1
welderboy14
Surrey, BC
John Deere 325
Hey,
i need a little help figering what port is the inlet and what one is the outlet Heres a picture,
Thanks for any Help
   / Joystick Help #2
Can you provide pictures of the other faces of this valve? I see a P & T on the view but would not want to hazard a guess on which ports they are from the picture you provided.
Roy
   / Joystick Help #3
P= Pressure, or IN
T=Tank or OUT
   / Joystick Help
:thumbsup:....also notice the relief valve in lower right on picture is on the pressure/in side
O ya i for got about the relief valve:laughing: , i guess i sould ask now how to set it to the right PSI relief:confused:
   / Joystick Help #7
After you get the valve all hooked up, you will attach a presure gauge (0-3000PSI) to one of the work ports-then activate the joystick to energize that port. The PRV (pressure relief valve) setting will be indicated on the gauge.
   / Joystick Help
Ok, thanks kenny for your help
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
Ranger Welder (A52377)
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
