Joystick Help
/ Joystick Help #1
welderboy14
Surrey, BC
John Deere 325
Hey,
i need a little help figering what port is the inlet and what one is the outlet Heres a picture,
Thanks for any Help
/ Joystick Help #2
Can you provide pictures of the other faces of this valve? I see a P & T on the view but would not want to hazard a guess on which ports they are from the picture you provided.
Roy
/ Joystick Help
:thumbsup:....also notice the relief valve in lower right on picture is on the pressure/in side
O ya i for got about the relief valve:laughing: , i guess i sould ask now how to set it to the right PSI relief:confused:
/ Joystick Help #7
After you get the valve all hooked up, you will attach a presure gauge (0-3000PSI) to one of the work ports-then activate the joystick to energize that port. The PRV (pressure relief valve) setting will be indicated on the gauge.
/ Joystick Help
Ok, thanks kenny for your help
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
Pair of 26in. 8 Bolt Combine Rims (A65640)
Pair of 26in. 8...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
Landhonor Diesel Heater (A66408)
Landhonor Diesel...
(2) Planter Boxes (A66408)
(2) Planter Boxes...
LOOK! (A63111)
LOOK! (A63111)
