jolly green
/ jolly green #1
JOLLY GREEN
dryden,ontario
jd214
having a problem with my 214, starts fine, after 15-20 mins, it starts to act up, seems to load up, notmuch black smoke, alittle, runs fair at 3/4 throttle.parts i have replaced, coil,carb,points,condenser, in line filter, some wires, clean fuel tank,new fuel lines. cannot figure it out, need help, thnx
/ jolly green #2
Check the vent in the fuel cap --- sounds like it might be plugged up. If it happens again, quickly loosen the fuel cap and see if it doesn't go away.
/ jolly green #3
I have agree it happened to me,take a straight pin an clean out vent hole,it worked for me.
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
1 Bottom Subsoiler (A65640)
1 Bottom Subsoiler...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
10in. Auger Bit (A65640)
10in. Auger Bit...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
