Joining Corrugated Pipe in Water
   / Joining Corrugated Pipe in Water #1
HIPO
Kansas
Kioti DK 35
Neighbor put a 2' (36" circum) extension on his corrugated overflow pipe for his pond when he built up the dam. He joined the extension to the old pipe with a metal band and some heavy duty silicone type adhesive. Well as you can imagine the water rose and the connection held together good, however there are a couple of leaks, pencil diameter streams of water coming through.
My question is: how can you stop the leaks? Weld from the inside somehow, etc. Any ideas would be appreciated.
   / Joining Corrugated Pipe in Water #3
How about some 2 part paste epoxy or some Bondo? Crawl inside when its dry and push it into the joint.
Expanding foam sealant would be easy, but I am not sure it would be waterproof.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
Pallet Fees (A50775)
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
Honda Pioneer 700 NR (A53424)
Honda Pioneer 700...
