Joining Corrugated Pipe in Water
   / Joining Corrugated Pipe in Water #1
HIPO
Kansas
Kioti DK 35
Neighbor put a 2' (36" circum) extension on his corrugated overflow pipe for his pond when he built up the dam. He joined the extension to the old pipe with a metal band and some heavy duty silicone type adhesive. Well as you can imagine the water rose and the connection held together good, however there are a couple of leaks, pencil diameter streams of water coming through.
My question is: how can you stop the leaks? Weld from the inside somehow, etc. Any ideas would be appreciated.
   / Joining Corrugated Pipe in Water #3
How about some 2 part paste epoxy or some Bondo? Crawl inside when its dry and push it into the joint.
Expanding foam sealant would be easy, but I am not sure it would be waterproof.
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
UNUSED (2) 30PCS Grey Metal Roof Panels (A53117)
UNUSED (2) 30PCS...
1999 Ford F-550 Bucket Truck (A53117)
1999 Ford F-550...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
