Joined the Kubota F-club
   / Joined the Kubota F-club #11
I've never seen one in the real....nor have I used a zero turn. How's your "F" compare to a zero turn....just wondering?
Cheers,
Mike
   / Joined the Kubota F-club #12
Cheers,
Mike
It all depends on your application. The F is going to give you better comfort, stability and traction and sacrifice some maneuverability over a zero turn. The closest zero-turn comparable to the F series Kubota would be a front-mount zero turn, such as a Grasshopper. I did try a Grasshopper 721D2 with a 61" mower, but was looking for a wider cut, a little more traction and more power. That's how I ended up with an F.
   / Joined the Kubota F-club #13
I want one of those now😡
Well, the F-3680 saga has so far, been a an “F” (letter grade A—F).
I got the machine 4 weeks ago, equipped with a new 72” commercial deck ready to cut, but within 5 minutes, it began to have hydraulic issues.
Immediately loaded it up and took it back to dealer. It’s been there almost 4 weeks. They split the tractor and repaired the PTO. I’ve been so busy, I haven’t had time to chat with the tech. The reason it has taken so long is they are NOT charging me for the repairs (north of $4,000) and so I think they are chipping away at it when time allows. I can’t prove it, but that’s my gut instinct.
I feel unlucky on this equipment purchase, but lucky they will cover the repair and lucky I didn’t sell my ZD331 which has served me very well.
They are threatening to finish the repairs this Tuesday or Wednesday. Then maybe I will be able to use it 12-15 cuts this year instead of the 20+ cuts I had hoped for.
Maybe when it’s back and useable for a few months, I can change the letter grade to a “D” or “C”?
I’m really curious about the traction and the overall ride quality. I mowed with mine for about 5 minutes and the cut was impressive, but it felt so much different to steer than a zero turn
   / Joined the Kubota F-club #16
That’s a major bummer! Very good that the dealer is working with you on the repairs. I think you’ll really like the machine when it’s fully operational. They definitely fill a niche.
Fingers crossed, but full disclosure- usually once a machine is split, I don’t trust it as much. Many parts need specific torque specs and factory assembly procedures. Nobody will be able to verify that was done.
   / Joined the Kubota F-club #18
Maybe sell dat muther just prior to the beginning of the season.... next year?
Sure would be a bitter pill. I looked high and low for one this clean and low houred
   / Joined the Kubota F-club #20
Won’t the dealer warranty their work? Like, if the same part/assembly broke a year after they fixed it… ???
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
2015 International Bucket Truck (A55973)
2015 International...
