John Deere4120 vs Kobota3940
   / John Deere4120 vs Kobota3940 #11
I don't think that's too light for its size. The JD 4120 is around 3750lbs, not a lot more. In either case I think you will want filled tires for stability on slopes.
I don't know if there is an objective answer to which one is better, but I can pretty much guarantee you won't find such an answer here! I think you should drive both extensively and decide which one you like better. Both will serve you fine. On paper there are some differences and a case can be made for either one, but in practice I think the differences are small.
   / John Deere4120 vs Kobota3940 #12
Lee77 said:
Kubota L3940 price is 500 less with the R1's $21,395. The weight of this tractor is only 3527 isn't that a little light? Is the Deere $2000 better?
It is far better to be able to add the weight where it is needed if it is then to have a tractor that is to heavy being a fuel hog, inefficient and fat. The added weight also wears out the tractors faster.
   / John Deere4120 vs Kobota3940 #13
My 4120 has filled tires and I pretty much always have the loader on. So what is my actual running weight, and on R4's? I dunno. I weigh 200 bucks myself, so that alone adds around 5% to the weight of the machine. Having a full tank of fuel adds 120 pounds itself. So, a few hundred pounds either way simply is not significant.
I really do enjoy my 4120. If I did it all over again, though, I'd go 4320. That extra 5 hp opens the door to a lot more attachments you can use.
   / John Deere4120 vs Kobota3940 #14
Lee77
Check your Pm's
   / John Deere4120 vs Kobota3940 #15
Golly! You sure have a sharp line to delineate between being, "to heavy being a fuel hog, inefficient and fat. " After all, the difference in weight is only a couple hundred pounds.
But on a serious note, I don't agree that the added weight wears out the tractor faster. Quite the contrary, heavier tractors often have superior traction due to the added weight. That allows for smoother operations. Shock loading is then reduced and shocks are tremendous initiators of cracks.
jb
   / John Deere4120 vs Kobota3940 #16
Being new to tractoring I can attest to the importance of tips provided to me here in this forum concerning hillside mowing:
1. Have ROPS and wear seatbelt.
2. Go up and down hill, not side to side.
3. Go slow.
4. Add fluid to tires.
5. Widen tire track by turning tires out.
6. Get AG tires
7. Don't mow when grass is either wet or damp
Helped me to have fellow farmer come over and watch him navigate hill, see how he did it was a big help. Also read as many threads concerning "steep hills" and read countless articles about recommended tractors. It helps that my tractor has four wheel drive with a locking differential. Watch out and stay away from holes, gulleys, and obstacles like rocks, logs, or large clods of dirt. Thorns can cause a leak in your tires, avoid thorns. If you don't get a front end loader, get some weights for front end. Join the local coop. A good dealer that is close by cannot be stressed enough. Unlike cars, the number of dealers for tractors are limited and a good dealer that is close by will make your life easier. Rotary cutters or bushhogs can really throw rocks far and hard, keep all children, family, friends far away. Cutters can throw rocks by your head - watch what you're cutting. Get your tractor's owner manual and repair manuals.
   / John Deere4120 vs Kobota3940 #17
Lee77 said:
JD 4120 with FEL power reverse ind.tires $23,674
Kubota 3940 with FEL GST ind tires $21,900
I don't know tractors that well. I think both will do my jobs. What do you guys think. one vs the ohter, thanks
If you are open to other brands, consider the Kioti DK40se. It is quite comparable to the 4120 and 3940 plus or minus a few bells and whistles here and there. Probably heavier than either the JD and certainly the Kubota. The HST version with FEL and R4s can be had for less than 20K and I'm sure the non HST would be even less. I've got only 20hrs on mine so far but am very impressed.
   / John Deere4120 vs Kobota3940 #18
One thought: The bull gear final drive on the Kubota will likely be noisier than the planetary final on the JD. It's not a big deal either way; I've gotten used to the sound it makes on my L4300. Planetary drives are fairly quiet, but don't ask me why.
FWIW
Bob
   / John Deere4120 vs Kobota3940 #19
jb
John Bud, when working with ag tractors we have found that the best performance is between 110 and 130 lbs per horsepower for tillage work. That is the best in fuel economy as well as overall life of the tractor. There is no reason to hit any more weight per lb on a compact tractor unless it might be used for loader work in more then 75% of it's duty and then I'd still have reservations. They actually recommend when mowing is in the application below 100lbs and perfered below 85lbs!
I have never seen a recomendation where traction should even begin to be 100% yet! For tillage they recommend 7% for plowing, there are good numbers on other applications to but for the most part we never see to much slippage other then in muck or mire with a compact on a day to day basis.
I do have one question back for you on your heavy theory, if your tractor is so heavy you have 100 percent traction that it doesn't slip, what gives if it does hit that magical point of extra load that it really needs to or should slip?
I didn't used to recommend that anyone not load the tires! Today our lighter tractors without loaded tires and more wheel spin don't wear them out faster but are often far more then double the life. I do know what the customers are telling me about overall performance and fuel efficeincy and that is what I try to enlighten people here about.
In a Case-IH product info book RF8-85 they had a hypothetical example that to pull a full load at five miles per hour your estimated transmission life would be 10,000 hours, if the max speed would be four miles per hour it would be 6500 hours life and if you could only pull the load at 3.5 mph your life would be reduced to only 1700 hours!
   / John Deere4120 vs Kobota3940 #20
Art,
I never mentioned % slip.
I doubt that the OP will ever do much where full power is transfered (or even the correct 93% of power). His statement is that he wants to mow on steep slopes and general FEL work.
From your numbers, the 39 HP Kubota should be 39hp*120lb/hp=4680 pounds. Taking the mid number you listed. It is an actual 3500ish pounds.
At 85 pounds/hp its 3315, or just about what the Kubota weighs. As he wants an FEL, having more than 85# would be good.
As he will be operating on sloped ground with an FEL, I feel the increased stability of filled tires is mandatory. Especially for a new to occasional user.
My stated opinion that heavier is better is that having perform operations in an abrupt or abusive manor (ram into spoils piles to fill the bucket, or pick up speed and drop a middle buster,etc) due to poor traction is worse for the machine than operating it in a smooth controlled fashion.
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
IH 445 Square Baler (A50515)
IH 445 Square...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
