John Deere with B&S engine battery Indicater
   / John Deere with B&S engine battery Indicater #1
mark1
Spencerport,NY
Jinma 284,Jd GT235,345,Trac-Vac1080
While mowing with my old GT235 occasionally the Battery Indicater light will come on.By the time I get off mower and open the hood it's off. Thinking a bad connection but where to look? and ideas? Thanks
   / John Deere with B&S engine battery Indicater #2
I have a GT 235 I bought used about 16 years ago. The battery light has been on since I bought the mower. I have never bothered trying to fix since it does not affect use.
   / John Deere with B&S engine battery Indicater #3
I take it that the battery is still getting a full charge even when the light comes on. Have you measured the battery voltage after you have finished mowing?
A fully charged cell at 80 degrees F would show a specific gravity of 1.265. If all six cells are fully charged, an accurate digital voltmeter reading of battery voltage would show 12.68 volts.
Could well be a bad connection or your battery is getting ready to fail. How old is your battery?
Richard
   / John Deere with B&S engine battery Indicater #4
Should your charging system and battery check out, I would think that the battery discharge sensor AM126691 could be the issue. That is if it is a 99 or 2000 model.
KInda late in the year to do much diagnosing.but will add a volt meter in spring when we start mowing but battery was replaced last summer...I'll look into the discharge sensor Thanks. MW
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
LANESHARK LS2 LOT NUMBER 159 (A53084)
LANESHARK LS2 LOT...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
BUSH HOG 2820 LOT NUMBER 128 (A53084)
BUSH HOG 2820 LOT...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
