John Deere with B&S engine battery Indicater
   / John Deere with B&S engine battery Indicater #1
mark1
Spencerport,NY
Jinma 284,Jd GT235,345,Trac-Vac1080
While mowing with my old GT235 occasionally the Battery Indicater light will come on.By the time I get off mower and open the hood it's off. Thinking a bad connection but where to look? and ideas? Thanks
   / John Deere with B&S engine battery Indicater #2
I have a GT 235 I bought used about 16 years ago. The battery light has been on since I bought the mower. I have never bothered trying to fix since it does not affect use.
   / John Deere with B&S engine battery Indicater #3
I take it that the battery is still getting a full charge even when the light comes on. Have you measured the battery voltage after you have finished mowing?
A fully charged cell at 80 degrees F would show a specific gravity of 1.265. If all six cells are fully charged, an accurate digital voltmeter reading of battery voltage would show 12.68 volts.
Could well be a bad connection or your battery is getting ready to fail. How old is your battery?
Richard
   / John Deere with B&S engine battery Indicater #4
Should your charging system and battery check out, I would think that the battery discharge sensor AM126691 could be the issue. That is if it is a 99 or 2000 model.
KInda late in the year to do much diagnosing.but will add a volt meter in spring when we start mowing but battery was replaced last summer...I'll look into the discharge sensor Thanks. MW
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
