John Deere Power Reverser won't Start
   / John Deere Power Reverser won't Start
Service/tech manual says nothing (near as I could find) on any adjustment. And I looked pretty hard because I thought there would be something, especially if an adjustment might be needed.
Don't know if something internal needs to be "in position" to detect its location.. might be possible to check that out after removal of the switch.
Also, if removed, might be able to check if it is functional too.
I did not find anything in the Service/tech manual either on the switch being adjustable.
But I did read in a post where the linkage is adjustable. But I just dont know where the adjustment is.
If there is one.
I want to thank everybody for your help with this problem!
I found the switch. Unplugged it. And sprayed WD 40 on it.
It seems to work fine now. I have had this problem in the past. And it only seems to happen on cold damp days so maybe this is the ticket! Thanks again everybody!
Part number of the neutral switch is LVA10617......
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Murray Push Mower (A57453)
Murray Push Mower...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Sedan (A59231)
Sedan (A59231)
