John Deere Polyurea grease compatible with Lithium grease
   / John Deere Polyurea grease compatible with Lithium grease #1
GatorDude
Raleigh
John Deere
Is the JD polyurea grease compatible with lithium greases?
I only have the top of the line JD Polyurea (not much more than the others) and purchased a chipper that made a comment about polyurea and lithium greases incompatibilitu. One checklist I saw said polyurea conventional is not compatible but shear table version is.
The JD writeup says "Compatible with most other types of grease" but no mention of the popular lithium.
   / John Deere Polyurea grease compatible with Lithium grease #2
I would think lithium would be in the "most other types of grease" since it is probably the most common type of grease of all time.
   / John Deere Polyurea grease compatible with Lithium grease #4
This brings up an interesting issue. If you buy a tractor or other equipment, how do you know what grease to use if the manufacture doesn't specifically call it out in the manual? Does it really make a long term affect that a homeowner/non-professional user would see?
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
