JOHN DEERE MX10 stupjumper
   / JOHN DEERE MX10 stupjumper #1
Fabiangarza
Kubota L4240 HST
Can anyone help, I can't get my stumpjumper off for repairs. Is there a hex screw? special equipment needed?
   / JOHN DEERE MX10 stupjumper #2
:welcome:
Isn't there a hole in the deck to access the nut that holds the blades? That same bolt holds the stumpjumper on, I think. Unless they now include the stumpjumper as a one-piece item and it is not separate from the bar.
thank you BEENTHERE
On the picture you attached, items # 8 and 9, I didn't see on my jumper. I did take the bolt/washer on the center of the jumper off and through the hole on the deck I hit the jumper planty but it didn't come loose. The only bolts I am able to see from the hole on the deck are those that attach the blades to the jumper. guess I need to go back and see if items 8,9 are there.
Isn't there a hole in the deck to access the nut that holds the blades? That same bolt holds the stumpjumper on, I think. Unless they now include the stumpjumper as a one-piece item and it is not separate from the bar.[/QUOTE]
   / JOHN DEERE MX10 stupjumper #4
Fabian
Better get the serial number. There is a break in the parts from MX10X14000 and up. Which side of that number do you have?
I didn't interpret what you stated
. Typo?
   / JOHN DEERE MX10 stupjumper #5
Silly question, why do they show the blades being beveled on both sides? Is that cutter hydraulically driven and reversible?
   / JOHN DEERE MX10 stupjumper #6
Ford tractor
The MX10 is two spindles with blades so maybe a pair can be switched between spindles ?? Maybe Fabian can confirm.
Ford tractor
It does have 2 spindles, usually I don't switch between spindles I just sharpen the blades and keep cutting.
I does have hydraulics and they work nice. I don't know exactly what you mean by reversible?
   / JOHN DEERE MX10 stupjumper #9
Fabian
Do you have the serial number ??
   / JOHN DEERE MX10 stupjumper #10
If it were hydraulically driven, you could reverse the spin direction of the blades
He's saying he put something through the access hole and tried to beat the stump jumper off
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Electric Concrete Mixer (A51573)
Electric Concrete...
2014 LAMAR TRAILER (A52472)
2014 LAMAR TRAILER...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
