Tires John Deere Material collection System Problems
/ John Deere Material collection System Problems #1
KEYBEAR
Indiana
John Deere X-758
I have the 14 bu. three bagger with Power Flow and we are now installing impeller number three in less then 8 hour run time . The first impeller was a factory mistake the second had a bunch of wear in 4 hours run time .
Now the dealer is going to put on one more ? Was told this morning JD went with the new impeller in around the year 2000 and a lot of problems ?? Anyone having the same luck ?
/ John Deere Material collection System Problems #2
What part number are the impeller's being installed?
Any pics of the wear you are getting?
I really do not know the part number . The wear on this last one was a bending back of the inside blade tip (1/4 inch all four)all four and a thinning of the edge at that point . It looks like it has lost 20% of the materiel at the outside tip of the blade . It has about 4 hours run time . The Dealer had a new Power Flow used for ten hours and it was fine . I do not run the Power Flow that hard as it dose a nice job running at about 80/85% engine speed . I can not do pictures as the Power Flow is at the shop .
/ John Deere Material collection System Problems #4
No problem with the impeller on my X324, and it has handled its share of small sticks and pine cones. I have had it for two years now.
/ John Deere Material collection System Problems #5
If the impellor is rubbing that may well be the cause of your earlier problems with excessive loading of the tractor and over heating.
At any rate I went and looked my blower and all is good after about 5 years and about 100 hours of use.
It is not rubbing No reason for the wear after only 4 hours of run time .
/ John Deere Material collection System Problems #7
There is a reason, just need to find what it is. ;)
When you can get some pics of a "bad" one, it would help diagnose from afar.
I'm on the same impeller (called a ROTOR by Deere) on my Power Flow since new in '97. Thought last year mine was wearing too much, so bought a new one (part M71340) but it didn't look much different in size and tip length so didn't change it out with the old one.
I maintain about 8 acres of wooded area so hickory shells, sticks, and walnuts are regular fare for this blower unit. Once in awhile, a stick stops it and requires removal, but not often.
Also, still on the original belt, but have a new backup just in case as this one is looking pretty marginal.
Got my Vacuum back today now one last (I hope) question please .
I thought I have been running the deck to close to the qround .
Today I set the deck at three inches and it did not do a good job .
Blew a lot out the left hand side and I had to go back over a bunch .
How low do you run the deck with a power Flow .
2022 EZ-GO ELITE...
John Deere Power Unit (A64047)
John Deere Power...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
HARDEE GATOR TAIL PTO PUMP (A63291)
HARDEE GATOR TAIL...
40’ Shipping Container (A64047)
40’ Shipping...
