John Deere LT 155 Drive Belt
   / John Deere LT 155 Drive Belt #1
elgatto
Spring City, PA
John Deere LT155
The drive belt or traction belt broke on my JD LT 155 mower. I have an operator's manual, but there is no diagram or info related to the routing of the drive belt. Plenty of info on the mower belt. I have a new belt and I need a diagram so I put the new one on correctly. Does anyone know where I can find a diagram which shows the drive belt on the pulleys and idlers? I tried google, utube etc without any luck. Thanks
   / John Deere LT 155 Drive Belt #2
:welcome: to the forum.
I'll see if jdparts.com has that. It is free registration and you can look there too.
Looks like two different ways, depending on serial number for the 42" deck.
Which to you have? Above or below 125001 ??
Here is the timing belt config for the deck below 125000 on the left, and above 125000 on the right.
   / John Deere LT 155 Drive Belt #3
A parts list exploded view may help with the routing. Otherwise, it's the repair manual you need. The owner's guides do not provide much in the way of service information. The power drive belt is a fair amount of work to change. Though the routing is not too difficult to figure out.
   / John Deere LT 155 Drive Belt #4
sounds like we need the traction belt info, not the deck, see if this helps
Thank you very, very much. Exactly what I needed..
mike dianna
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
