John Deere L130 Smokes
/ John Deere L130 Smokes #1
gatkins94
I have a John Deere L130 that every time I start it up it blows enough smoke to run you out of my two car garage, the engine has 50 hours on it, and recently was taken back to the service center for this for the second time. The first time John Deere told the service rep to replace the Head gaskets, which I knew would not fix the problem, now this time they are replacing the engine. The problem I have is that Kohler says that it's because of the angle the engine is mounted on the mower, and not really a problem. Has any of you heard about this issue with the Kohler 23hp engine on the L130? or is this an isolated case, and a new engine would solve the problem?
/ John Deere L130 Smokes #2
I wouldn't think that is normal. I'm sure a new engine will fix the problem. If it was due to the angle on the engine, I dought that JD would have sold all of them with that problem. I bet once you get it back with the new engine you won't have to worry about that problem any longer.
Good luck!
/ John Deere L130 Smokes #3
Yeah , My Dad bought one of those Homedepot specials and had the same problem.... Sent it to the dealer two weeks later he gets it back with some song and dance about the problem (i'm forgetting now what was said ,but it wasn't possible).
He gets it back same problem and two weeks later it quits smoking ,maybe it finally broke-in who knows, or it could have been fixed at the shop,maybe they rebuilt it /forums/images/graemlins/confused.gif
Is it possible he started parking it with the front end uphill?
/ John Deere L130 Smokes #5
No , I beleive it is parked level in the shed , but I see what your thinking.. I beleive that some of his trouble may have been slightly overfilling the crankcase,which could cause the smoking trouble. But if you follow their instructions you may be overfilling the crankcase. The instructions say to check the oil level without screwing the dipstick in ,just dip-it in to the top of the threaded tube, the difference in the oil level between screwing it down to check or just dipping it may be the difference in having too much oil in the cylinders getting past the rings or initial crankcase pressure until warm-up when the rings expand /forums/images/graemlins/confused.gif MAYBE ??
That's exactly what it is. The Kohler people have figured out that to eliminate the problem all together you need to use 1.7 quarts of oil instead of 2.0 like the John Deere manual states. I'll be using the 2.0 since if I don't, I'm sure I'll have warrantee problems. Kohler did say that even though this has been a problem, all of the engines don't smoke, which leads me to believe the rings are seating properly on some, but not all.
Well, they've replaced the engine with a brand new Kohler Command 23 and guess what? This one smokes worse than the first one did! I can't be the only one with this problem, and I'm sure i'm not doing anything wrong. I understand engines, I've built a few Small Block chevy's and a big block, so I'm not lost in the garage, but this is something else. We'll see what's next on the list for John Deere to do.
/ John Deere L130 Smokes #8
Is it oil smoke or running rich? We're still learning the idiosyncrasies of the the Kohler Command 16 in our LT160. It seems to be very touchy on choke - it only wants to be choked when it's *completely* cold (first start of the day). Afterward, even after sitting hours, it seems to be much happier starting with just part-throttle, full choke start position smokes it up.
It's definately oil smoke, I take pictures every time I start it up. I would post a couple of pictures if I could figure out how. It's actually simple, unless you always park the mower with the front end up hill, it's going to smoke, I'm just wondering if i'm the only one that thinks that's odd.
/ John Deere L130 Smokes #10
gatkin, I talked to my Dad, He said they told him it was the reed valves?? In a four stroke HA-HA yeah right Ok then well while your at it check the muffler bearings /forums/images/graemlins/crazy.gif
Well at this point your best bet is to drive it like you stole it!!
Run the snot out of it ,that will help break it in ... Those motors are supposed to be designed to run at full throttle which helps cool them by way of the flywheel fan.. Just don't overfill it with oil and it should break-in sooner or later.
My Dads quit smoking about 3 weeks or so after getting it back.... Good luck /forums/images/graemlins/grin.gif
/ John Deere L130 Smokes #11
What kind of oil are you using in the mower ? If synthetic, maybe that is keeping the rings from seating properly or as fast.
Ben
/ John Deere L130 Smokes #12
Synthetic oil will not cause it to break in any slower or faster than normal. Many new vehicles now come with synthetic oil right from the manufacturer.
/ John Deere L130 Smokes #13
Gatkins, if you drop the oil level closer to the "ADD" line on the dipstick, does is still smoke? Today's OHV horizontals are super sensitive to oil level. Some will belch a cloud of blue if even too close to the "FULL" line on the dipstick.
G/luck
Joel
/ John Deere L130 Smokes #14
You are not alone. My L130 may or may not smoke badly when started hot or cold. If John Deere/Kohler position is that it's normal or if a new engine does not solve it I won't bother pursuing the problem. By the way I don't buy the breakin thing as mine has over 110 hours and still does it. I use John Deere oil and filter when oil changes are due also.
/ John Deere L130 Smokes #15
slowrev, Just noticed your question , Been working a good bit of OT the last few weeks and it starting to show... I'm pretty certain my Dad uses castrol 10w-40 , But his mower isn't smoking anymore (must been the 12 step program) /forums/images/graemlins/crazy.gif
Its been doing fine for sometime now ...so-far /forums/images/graemlins/smirk.gif
Detroit Diesel 3 Cylinder Power Unit (A64912)
Detroit Diesel 3...
2011 CHEVROLET IMPALA CAR (A66091)
2011 CHEVROLET...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2015 CATERPILLAR AP1000F ASPHALT PAVER (A65056)
2015 CATERPILLAR...
2011 Bobcat T190 Compact Track Loader Skid Steer (A66734)
2011 Bobcat T190...
Fuel Storage Tank (A68134)
Fuel Storage Tank...
