John Deere Hydraulic fluid
/ John Deere Hydraulic fluid #1
kartvines
Quick question,, just bought a JD 770 compact tractor, looking at the manual of course the book says to use only John Deere Hydraulic fluid. I would guess that any good quality fluid would serve the same purpose. Welcome feed back.
/ John Deere Hydraulic fluid #2
Anyone can weigh the risk of using something else, and probably come out just fine.
I just use the Deere oil, as it isn't much more expensive (I don't know if it is at all). In 5 years I have changed the transmission oil once. Have you calculated what you would save by buying something else?
In my manual, it says Deere Hy-gard I believe, or its equivalent (and then gives the specs of the equivalent).
/ John Deere Hydraulic fluid #3
My first thought....
If you just bought your 770 new, would you need fluid for adding? If so, it is not a good idea to mix different oils.
Second thought - fluids are very important - with my machines and vehicles I don't scrimp - not worth the savings of a couple bucks.
But....if I had a 30 year old machine that wasn't in the best of shape and was a real leaker, I might opt for the cheap stuff.
/ John Deere Hydraulic fluid #4
Ditto the thinking of the previous posters. Service a $15k tractor with "the cheap stuff" to save maybe $20? Not worth the risk to me. Plus, I have a good dealer so I am happy to support those who support me.
This was a used tractor with many hours logged, how do I now know what fluid is currently in the system. I installed the backhoe and had a hose leak so I want to top off the fluid.
/ John Deere Hydraulic fluid #6
If you do not know what fluid is currently in the tractor, then you may not know it's quality either.
If it were me, I would change it all and put in the recommended JD hydraulic fluid.
Richard
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2025 Spirit Electric Scooter (A61574)
2025 Spirit...
2017 Ford Expedition SUV (A61574)
2017 Ford...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
